Results 1 to 9 of 9
Thread: 12v Fans directly to battery?
    Variable Bitrate Phatsacks's Avatar
    May 2007
    Springfield, Va
    I have two case fans that I believe are wired directly to the battery (I did not install these myself).
    Just wanted to check to make sure that this was fine, before they end up melting one day down the road.
    Elsewhere
    I think they should be fine.
    When the car is running, the fans would spin faster, as they would be receiving ~14v (depending on your alternator output) which might decrease the life of the fans somewhat. I don't think it would be a big deal, though.
    How about the Wiki?
    May 2007
    Springfield, Va
    As always, thanks Darque, appreciate the confirmation/opinion.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Typical fans would not be sensitive to the surges and dips in voltage in a car's electrical system. As DP said, the fan speed would tend to vary somewhat but it wouldn't hurt the fan. An observer would probably not even be able to see the difference. Basically motors, relays, solenoids, lamps, and heating elements are usually tolerant of unregulated supply voltage. PC's on the other hand need regulated voltages.
    ~Jimmy
    Jan 2008
    Southern Calif
    So are they on all the time?
    May 2007
    Springfield, Va
    Nope - Guessing they are switched with ignition start (ACC line?) They are also in the same box as the amp/carpc, which also has the distributer block, so maybe something off that as well. But not on all the time.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by DarquePervert View Post
    Agreed. I would not hesitate to set up like this for case fans.
    TruckinMP3
    Read the FAQ!
    May 2007
    Springfield, Va
    Nice - Appreciate the confirmations, I feel better about them now.
    Once I get my car back, I'll do a full write up of the work that was done, and will see what gets knocked on.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Glad you posted this question, I have 4 big center console fans, and did not want to power them on the PSU, so I connected them to my switched 12v line.....
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  1. Amps killing battery
    By exhumis in forum Car Audio
    Last Post: 05-30-2007, 05:01 PM
  2. XMDirect powered directly from car's battery?
    By vadimr in forum Power Supplies
    Last Post: 05-23-2006, 07:35 PM
  3. Replies: 1
    Last Post: 06-27-2005, 09:16 AM
  4. Dual Battery Setup?? Help!
    By Derek Lee in forum General Hardware Discussion
    Last Post: 05-15-2005, 06:45 AM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
