Results 21 to 30 of 37
Thread: Visteon HD reception woes
  1. #21
    Jan 2005
    Quote Originally Posted by HiJackZX1 View Post
    Maybe you have a ground loop? Try doing Mitch's mod were you add a ground cable to the RCA port on the Visteon. Maybe thats why you have interference?
    I thought about that, but Jake on the first page said this,
    "The grounding method is only good if its installed on a bench outside a car."
    So is that right then? I havent had time to get another antenna... pretty hard to find one OEM. I need to stop by these salvage yards i guess.
  2. #22
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Figured i would throw my experiences out there...
    I've had interference issues for a while... to be honest i haven't even used it in a while.
    I've taken everything out of the car, used it inside, bought ferrite split beads, isolated components, ... the works.
    What I have found is that something from the carPC itself is causing the interference.
    I powered the computer off an ATX bench supply I have, and there was definitely less noise... which points to the M2-ATX as the problem. But there was still some problems.
    Something you should try to see this is to control your Visteon with the control brick... have your computer running, and then shut-off your computer. I almost guarantee you will see a signal boost or a quick lock-on to HD. It worked for me every time.
    So that's where I'm at. I haven't really messed with it lately..... but darn that RFI!
  3. #23
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Quote Originally Posted by utd09bry View Post
    Interesting. I have an Opus PSU, and it's so nice and does exactly what it's supposed to do, I'd hate to think it's causing my problems, but it just might be! So what could we do if this were in fact the problem? Encase our PSU's in big ferrite boxes??
  4. #24
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    i'm running the visteon with a M2-ATX with no issues. Mine gets great reception pretty much anywhere.
    I get the same results with centrafuse, the program from mitch or RR with DFX 3
    The only thing I get that is strange is one HD station kinda switches from stereo to what sounds like 3d stereo.
    肚子笑痛了
    S60 Install
  5. #25
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Nola111 View Post
    hahahahaha, wonder how much a big ferrite box costs. Where do you guys have your PSU's. My OPUS 320 is right next to the MoBo, they are almost literally touching each other. Only interference i have is when i turn on and off the PC, I get this wierd high pitch sound only at start up and shut off. This is happeneing through the onboard audio port. Im hoping that with the USB card I wont have the issue since it is far from the PC.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  6. #26
    Jan 2007
    New Orleans, LA
    I have mine (also Opus 320) in a plastic Radio Shack project box, and that box is on top of the pc. The Visteon unit is approx. 2-3 feet away from the pc. Too close maybe?
  7. #27
    Sep 2007
    Dallas,TX
    i have heard of others having success using the M2-atx... i almost have a feeling that its just my motherboard. computers generally put off a lot of high frequency noise.
    the only way to shield RFI is through isolation and shielding (metal). plastic casing won't do anything..
    don't forget that cables can produce noise in nearby cables... including antenna lines
  8. #28
    Jan 2005
    FIXED!
    It was the antenna. I picked up an Oem antenna from the dealer yesterday ($20 for the mast) The radio is now crystal clear. Although...
    I believe i have some sotware issues that need working out, as it sounds like it might be overmodulating a little bit. Does the input from the HD radio pass through any EQ's in the software before being pumped out to the line out? Im using the DFX3 skin.
    Also, on the "Music" side of things, the default for my winamp volume wont stay full-on from the previous usage. I have to turn it back up from +-25% every time. Any Ideas?
    Thanks for all your help! Mitch was dead on in the first reply of this thread.
  9. #29
    Jan 2007
    New Orleans, LA
    Great to hear rock99! Would you be able to post a pic of the antenna? I know that since you got it from the dealership it won't be the same as for my VW, but if I could see what it looks like, I'll look for something as similar as possible.
  10. #30
    Sep 2007
    Dallas,TX
    Anyone having problems... have you tried using the hd radio without your computer running to see if you get better signals? Just using the control module, whether you have speakers running or not, you should be able to see how quickly it locks onto stations. This was the test I used... and since I have my computer connected to a switch on my dash I could easily flip it on/off... and the radio would respond with a quick lock-on or an instant loss of signal. It was quite amazing... Now just to figure out which component or wire is causing that mess
  1. Visteon HD Radio and December Binary problem.
    By Deanw1968 in forum Newbie
    Last Post: 02-08-2008, 01:56 PM
  2. Replies: 8
    Last Post: 01-27-2008, 09:34 AM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
