Good deal, thanks.
Good deal, thanks.
LESSON LEARNED:
For anyone experiencing bad reception or having a hard time locking on to an HD signal...
I am set up with the Visteon mounted about 2-3 inches from my PC case. I experienced horrible reception initially (using the OEM Hyundai antenna) and later replaced it with an aftermarket antenna. I was disappointed to hear that the reception was still horrible. Somehow I got thinking about what might be the problem and I remembered back to the days of CB radios and problems with ground planes. I wondered if I HAD NOT GROUNDED THE ANTENNA ASSEMBLY PROPERLY. That was it. I made sure that the bracket that has little teeth on it and that grips onto the back side of the car body panel was properly getting ground to the body panel and that the gripper thing was making contact with the casing of the antenna. This cleared up all of my issues. NOTE: I'm not talking about the ground wire that serves as a ground for the power antenna motor. I'm talking about the antenna itself. BOTH need to be attached to ground (the car's body).
I finally got around to setting up my hd radio and I am having reception issues. I hooked everything up downloaded software got the pc to control the radio, but I wasn't picking up anything except one station. I did some research and found out that my antenna was powered by the head unit so I got a pin out of my radio harness and connected the antenna wire to a 12v wire. Now I'm getting about 50% of the stations I got with stock headunit no HD and the stations I'm picking up aren't coming in very well. Any suggestions on troubleshooting would be appreciated.
I was told not to bother with that since they barely do anything, if anything at all. So, I didnt bother.
I don't know if I said this before, but I had horrible sound from my HDRadio. I had my input going to the stock sound card and output from the external sound card. Right before I gave up, I connected everything to the external sound card and it now sounds great.
You'de be surprised who's visited my blog (including the FCC and most automakers), since it sits on Google's Homepage for searches on "hd radio". For the past two years, iBiquity and the automakers have been under investigation by two law firms for auto fraud, in hopes of filing class-action lawsuits. This may include non-HD broadcasters over interference from HD broadcasters, too. BMW and Volvo have tried to install HD Radio standard, but have ended up with ongoing Technical Service Bulletins against HD Radio.
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
