Results 1 to 4 of 4
Thread: problems from road vibration
    Aug 2000
    Question problems from road vibration
    doesn't hauling a cpu (especially a desktop) around in your car damage some of the sensitive components like the hard drive due to extensive vibration?
    what are the best ways to prevent this damage?
    [This message has been edited by seven10split (edited 08-06-2000).]
    Sep 1999
    Yarmouth NS, Canada
    I've never really had a problem with vibrations affecting the computer in my car.. but I avoid pot holes and go really slow through rough roads, speed bumps, etc...
    Now, with that point made, I wouldn't go offroading with a harddrive running either.. My hard drive is mounted on its side and hasn't had any problems with data errors or skipping or anything like that.. Mounting on it's side is probably the best bet because it pretty much eliminates the platters touching in a really brutal jar (and it would have to be REALLY bad)..
    If you are really nervous, suspend the hard drive in some sort of caddy with rubber bands or strapping.. This has been done by quite a few people and seems to be a pretty good solution if you have the room and ingenuity to to it. You also can't go wrong with foam or rubber gromits on the drive to absorb some of the shock.
    The hard drive is the only thing I would worry about in my system, because its the only main mechanical component.. Everything else is solid state and shouldn't be a problem.
    MP3 Cavalier -
    MP3 Grand Prix -
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    This has been answered hundreds of times before. Doing a search should turn up some answers.
    For what it's worth, hard drives are a lot less delicate than people think.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Jan 2000
    I have recently tested a laptop drive in my player. I was having some issues with skipping despite having the drive on it's side (and in winME, reboots even!).
    I have to say, the laptop drive worked like a charm. I took the unit over the roughest regular road I could find (for those of you in N'ville, you know I mean West End , and not a single skip, reboot, etc.
    Venomous MP3!
    CarMP3 system:
    200mhz, 20gb hotswapable drive, 128mb, Winamp w/full-screen vizes, (upgrading to WinAmp3 in near future), 5" LCD screen, controled by numberpad, Sproggy PS under construction, custom mounting case under construction.
