Results 1 to 10 of 10
Thread: Intel D201GLY2 with 1.33 GHz Celeron Processor
    Dec 2006
    Is this board 1.2ghz or 1.33ghz? I have the D201GLY2...and on the box it's say 1.33ghz but in windows it's 1.2ghz. Here a pic of the box.
    [media]http://home.austin.rr.com/soloxp/images/pic/intel%20boxd20.jpg[/media]
    Do I need to call Intel about this or...is there something in the bios I miss?
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    either way its still a great board..
    from memory, if it has SATA its the 1.2 and of it only has IDE its the 1.33
    Sep 2005
    Redmond, WA
    Also, it may be clocked down, Windows will show you the speed the CPU is at right now. If the CPU decided to downclock since it was not utilized 100% then you will see a decrease
    Mark
    See all my CarPC projects
    Mar 2006
    Blog Entries
    1
    D201GLY uses a 1.33Ghz Celeron 215 processor
    D201GLY2 uses a 1.2Ghz Celeron 220 processor (lower hz, but faster processor). Mine reports 1.2Ghz in Windows.
    Dec 2006
    Quote Originally Posted by Woofnstuff View Post
    You right about it been a great board. I took back the VIA C7 1.500ghz because it had high cpu usage with RR and FreeIce...But this board the cpu usage is a lot lower.
    Thanks for the info guys.
    Oct 2007
    Auckland
    check out the new intel boards comming out real soon too
    http://www.mini-itx.com/2008/03/06/i...based-mini-itx
    Mar 2006
    Blog Entries
    1
    Only four USB ports on that upcoming ATOM M/B means I'll never buy it. I'm staying away from USB hubs as they seem to cause hibernation or other issues, so having several USB ports is important to me.
    Mar 2008
    New York
    With my D201GLY2, I ran dxdiag in Windows and it reports back an Intel Celeron 220 @ 1.2 GHz and my packaging says 1.2 GHz on the sticker.
    BlackStealth, I was a little bummed too when I realized that my D201GLY2 only had 2 USB ports, but later realized that I could add 4 more for a total of 6 by extending the USB headers on the motherboard using expansion slot mounted USB ports. So, I have 6 total. Maybe this new motherboard will offer a similar option and you'll be able to have 8 total instead of 4.
    Vendor - Mo-Co-So
    Nov 2005
    No such luck for the USB. It will have 4 on the I/O shield and a single header for 2 more, total of 6. But the ATOM CPU is amazing. 1.6GHz at only 4 watts! They will also release a Dual Core ATOM 1.6GHz in August that will consume just 8W
    The new BLKD945GCLF will support up to 2G of RAM in a single DIMM socket via a 2G RAM module
    Mar 2006
    Blog Entries
    1
    The Atom M/B that I was referring to earlier was this one (http://mini-itx.com/96533563) -- it only has 4 USB. However, the BLKD945GCLF looks good to me with 6 USB ports.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Replies: 2
    Last Post: 03-10-2008, 10:56 AM
  3. FAQ REQUEST: CPU Ratings
    By dontpntpool in forum General Hardware Discussion
    Last Post: 03-18-2007, 03:39 PM
  4. AMD AM2 CPU Low Wattage
    By ACE in forum General Hardware Discussion
    Last Post: 06-11-2006, 04:13 PM
  5. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 02:56 PM
