Results 1 to 5 of 5
Thread: New Ibase 3.5 inch Atom based board
    Oct 2003
    Copenhagen, Denmark
    Anyone seen this : http://www.ibase.com.tw/ib882.htm as far as i can tell the Atom and its chipset can handle x.264 no problem, maybe this could be a good board for low-power, low-noise, low-heat htpc and for carpc 2.7Watts does not require much of a PSU, and it's only 12V :-)
    Not doing carpc anymore
    Constant Bitrate bl3nd3r's Avatar
    Jun 2006
    Pickering, Ontario, Canada
    I wonder how much this board is going for. If it is reasonable then it might work great, however, many embedded systems like this can be quite pricey.
    Oct 2003
    Copenhagen, Denmark
    I know :-) i have just gotten the LS-372 from commel, same size for core 2 duo which is about 200 for the motherboard alone
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    Feb 2007
    Fox Valley, Wisconsin
    Portwell also has an Atom board in the 3.5" form factor.
    http://www.portwell.com/products/det...CHAR1=PEB-2736
    I don't much like either board right now. iBase went with a PCI-104 connector instead of mini-PCI or mini-PCIe, and Portwell went with SDIO which is even less useful to me. At least I can find a PCI104 mini-PCI board.
    Still hoping there'll be a good Atom board. Been playing with Geode GX1 and Via C3 3.5" boards over the last few days. The Geode@300Mhz pulls 6 watts of power and the Via@667MHz is about 15 watts. The Atom would be about half the Geode with 4-5x better performance. Just plain wow.
  1. PC/104 based RDS FM radio + TV board
    By Smukkasen in forum General Hardware Discussion
    Last Post: 07-30-2004, 09:20 PM
