Results 1 to 3 of 3
Thread: Smart Junction Box -- 2001 Mustang -- Daytime Lights
    Vendor - Qube colin's Avatar
    Dec 2006
    Exclamation Smart Junction Box -- 2001 Mustang -- Daytime Lights
    I'm trying to enable the daytime running lights on a 2001 Mustang. As far as I know, there are 2 types of smart junction box -- ones with DRL and ones without. I believe I have the one without.
    Now the best way I thought of enabling the Daytime Running Lights would be right at the junction box. Rather than buying a new one... my idea is this:
    - Use the voltage from a pin that is on when the car is started
    - Attach it to the pin called "Park Lamp Signal"
    This *should* leave my park lamps on every time the car is started. Does anyone have any other suggestions or information as to why this would/wouldnt work?
    Thanks a lot
    Dec 2006
    Has anybody every messed around with their own smart junction box and have some insight before I destroy my car?
    May 2007
    Usually daytime running lights are the headlights not the parking lights. If you want the daytime running lights you can do it a couple different ways. First get a spdt relay (radio shack , parts store, etc.), It will usually have 5 pins on them.
    85- negative of coil
    86- positive of coil
    30- common
    87a- n/c or normally closed to pin 30 at rest
    87- n/o or normally open to pin 30 at rest
    Take pin 85 and goto brown wire at light switch(parking light wire)
    pin 86 goes to red/lt green at ignition harness
    pin 30 will goto yellow/red wire on the headlight switch
    Pin 87 will goto 12v constant on the light switch (don't know the color) or to the yellow wire with a 20a fuse.
    Now when ever you start your car only your headlights will be on.
    but when you turn on you parking lights your driving lights will go out.
    There's a couple diff config you can use.. If you don't like that one we can change it.
  1. 2001 V6 Mustang, Mac Mini, 7" Lilliput
    By mustanglou in forum Show off your project
    Last Post: 08-06-2009, 12:10 PM
  2. Indexing music in Failed
    Last Post: 07-07-2007, 11:19 AM
  3. 2001 Mustang Aftermarket
    By possesser in forum Car Audio
    Last Post: 02-12-2007, 08:46 PM
  4. Crazy Idea
    By isphius in forum Car Audio
    Last Post: 06-22-2006, 07:10 PM
  5. Replies: 10
    Last Post: 07-01-2005, 10:04 PM
