Results 1 to 6 of 6
Thread: USB extension
    Sep 2000
    LA, CA, USA
    USB extension
    How important is it to use shielded cable for a USB connection? I want to make an extension to the front of the car. This isn't for high data rate either....just for my D-Link USB radio. Will using cat 5 be sufficient? P.S. how many wires in a usb cable? 4+ground?
    Sep 2002
    Just North of Toronto, Ontario, Canada
    I believe it will be alright, just try to get high quality cat5 cable. USB is 4 lines including ground.
    Project AutoBoxen: Coming along, almost ready to hook up in the car.
    Celeron 500, 192mb ram, 8gb hdd, other stuff.
    '91 Mazda 626: Its free, so ill use it.
    Feb 2002
    I would recomend using one of these to extend your usb. they are guaranteed to work and they are pretty cheap (I have 3 myself).
    sv24, 733mhz celeron, 80gig hd, 5.6" MA Audio tft, x10 remote, RF Keyboard.
    Sep 2000
    LA, CA, USA
    I don't want to get one of those because my cable length is only going to be about 20' max and like i said there isn't going to be much data going back and forth on the connection, so i think it's a waste of money.
    Constant Bitrate henkbliek's Avatar
    Dec 2002
    Netherlands
    If I was you I would get an ordinary 5m USB extension cord. You will get a bit above spec (total 6m or so) but I think that's better than using other cable.
    Regarding your primary question. For in-car applications shielding is definitely important, much more than in your home. This because high currents flow everywhere in your car, there can also be ignition noise.
    BTW. The data rate on the USB is not determined by the application but by the standard (communication takes place at 12Mbps if you use it or not).
    Henk
    white bream
    working on a trilogy: CARGO - UNIGO - MERGO
    CARGO = the Car Computer
    Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
    Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
    Jul 2000
    Ottawa, Canada
    i taped together three 4ft USB cables and it worked fine using lowspeed stuff.
    [SIZE=1]'91 Nissan Stanza
    [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
    Car Totaled and i bought a 20G mp3 player
    http://machs-fuel.tk
    a DIY video projector page
