Results 1 to 4 of 4
Thread: USB hubs
    Jun 2007
    Chicago
    USB hubs
    I have 2-7 port USB 2.0 hubs on their own power. However, when I plug in a device I constantly get the message that this device can perform better in USB 2.0 hub, blah,blah,BS
    I have 2 extensions running from th trunk, one for each hub. Each hub also has a step down controller dropping 12v to 5v. The 12v is a separate circuit on a fuse block and is ignition controlled.
    Any thoughts from those more experienced?
    Thanks.
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    is your usb port on your pc 2.0 as well?
    My carpc worklog
    Jun 2007
    Chicago
    Just double checked the owners manual, all ports are 2.0
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Did you check your bios? usually you have the option of enabling 1.0, 1.1, 1.1+2.0, 2.0 only, etc. Check if 1.1+2.0 is selected.
    I've heard that if you plug old, "unfriendly" USB 1.0/1.1 devices into a hub, that then all 2.0 devices in that hub will automatically sync with the slower device. Some hubs avoid that, some don't. I would plug both hubs first, the problem device you get the warning from, and go from there.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Car Plugs for USB hubs?
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 09-13-2007, 02:25 PM
  3. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  4. Replies: 2
    Last Post: 02-09-2007, 11:43 AM
  5. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
