Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 62
Thread: Anyone try the Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
  1. #11
    May 2008
    Stable Dos...
    What kind of errors did you get, and when did they occur?
    Did you power the CD-ROM from an automotive PSU?
  2. #12
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    Quote Originally Posted by TSOfWaltham View Post
    I had some time to play with the board last Saturday and the experience was not good. I could not install linux/Vista/XP. All of them crashed during install. Only thing stable was DOS.
    hmm, i had somting simmular with my commell. Xp installed fine with the sata disk, but XP would't install on a ide. Turned out that the sata was ide 0 and ide was ide 1
    XP wants to install on ide 0, you need to check the bios for that, so try a different sata port.
    Hope you get it running
  3. #13
    May 2008
    No not yet. I switch the SATA ports between DVD drive and Hard drive. Still no success. The BSOD bug check code is 8E. It happens immediately after all the files are copied to hard drive (probably when windows takes control and starts running the boot drivers).
  4. #14
    Feb 2007
    netherlands
    8E its a bit out of my leage , but found a few quotes on the BSOD bug 8E:
    Quote Originally Posted by Tedster
    usually indicative of hardware failiure. Run memtest86+ from a floppy.
    Quote Originally Posted by howard_hopkinso
    Hello and welcome to Techspot.
    Both your minidumps crash with 1bit memory corruption.
    Go HERE (http://www.techspot.com/vb/topic35103.html) and follow the instructions.
    It is true that some faulty ram can pass Memtest. If memtest gives your errors, your ram is bad.
    Quote Originally Posted by SnowDog
    The 8E error points at RAM problems. It's pretty unique for a STOP code in that it only points at RAM problems when you look it up! So there's a good start.
    There are a couple of ways to diag it.
    You don't say which PB model it is, but if it has two sticks of RAM you can try removing one of the sticks to see if the problem persists, and then swapping with the other stick likewise.
    The other way is to download a RAM test utility and run that.
    I can onely find 8E code with ram problems, so i think thats where you should look first.
    ps win 2000pro installed without any problem on that system (its les picky about the ide number) so with win 2000 you have one thing less to look at.
    Hope its the ram, and you can fix it / get it fixed
  5. #15
    May 2008
    I have another RAM and will try tonight.
    Thanks for the pointer.
  6. #16
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    OMG, they are available in my country now...
    $103NZ ($81US)
    now... do i buy one... not that i NEED one, my D201GLY is working sweet.
    or should i wait untill the dual core version comes out
  7. #17
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    Quote Originally Posted by Woofnstuff View Post
    $103NZ ($81US)
    if you planned to downgrade...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
  8. #18
    Oct 2007
    Auckland
    yeah ive been reading lots of things since posting (i had a really quiet day at work)
    I'll be waiting untill the dual core atom comes out, hopfully that will be faster than the little valley, if not i will stay with what i have
  9. #19
    May 2008
    Hungary
    dualcore is faster only if the software is multi thread optimized. i think the mainly used softwares are not by this time... and as i know my C3 notebook, 2 from this CPU are slow too...
  10. #20
    May 2008
    OK. It was faulty RAM. After replacing the RAM, Vista installed just fine and was very stable. But I did not have much time to play with afterwards.
  1. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  2. Replies: 5
    Last Post: 05-11-2006, 07:48 PM
  3. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  4. Micro ATX / Mini ITX (AMD, Intel, VIA)
    By wanjer in forum Newbie
    Last Post: 09-11-2004, 08:31 AM
  5. Replies: 2
    Last Post: 10-24-2003, 10:28 PM
