Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 62
Thread: Anyone try the Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
  1. #41
    Apr 2008
    Quote Originally Posted by rijk View Post
    Is there any US company that is selling this heatsink?
  2. #42
    Jul 2001
    what do you mean by vga noise if you dont mind me asking?
  3. #43
    Jul 2006
    now the board seems gr8 - how do u intend to get the display??
    ::CONFIG::
    Pentium 3 @ 950Mhz
    Intel 815 MOBO
    256MB RAM
    80GB HardDrive
    DVDROM
    ATI Radeon 9200
    ATI Remote Wonder
    235 ATX SMPS
    500VA UPS
    300W DC to AC Inverter
    ::FRONTEND:: I need suggestions please
    ::OPERATING SYSTEM:: TinyXP
  4. #44
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    Quote Originally Posted by noIQ View Post
    Zalman's NB cooler family might be ok, but a DIY clip is required:
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
  5. #45
    Jul 2006
    Can any one help me getting display to RCA??
    as in if i use this mobo- how do i get the video out..
    ::CONFIG::
    Pentium 3 @ 950Mhz
    Intel 815 MOBO
    256MB RAM
    80GB HardDrive
    DVDROM
    ATI Radeon 9200
    ATI Remote Wonder
    235 ATX SMPS
    500VA UPS
  6. #46
    Low Bitrate loginfailed's Avatar
    May 2007
    Texas
    Thread is a bit dated, but I just thought I would report back. I changed from a VIA VB7001 to this Intel Atom board. This board is very stable and runs my carPC setup flawlessly.
    I ordered another one to use in the house for media storage & light HTPC use.
  7. #47
    May 2007
    Same here, i replaced my VIA VB7001 with the D945GCLF, and love it so far. Centrafuse with iGuidance and music playing in the background shows 2% CPU usage while on 2GB of RAM and running off of Windows 2000.
    My only problem so far is the boot issue, i'm using the M1 ATX power supply, and when I turn the car back on the MB does not power up by it self but I have to manually hit the reset switch, which does not bring the system out of hibernation but resets the whole system, which takes 60 minutes to end at the centrafuse main screen.
    But video is smooth like butter, and stays cool like fonzie!
  8. #48
    Jan 2009
    Dallas
    PCI Riser and Intel D945GCLF / D945GCLF2 Atom
    It took me many hours to figure out which jumper configuration works, but I figured out how to use the VIA 1 to 2 PCI Riser VIA-EXT with the Intel Atom boards:
    If you are looking at the riser, PCI gold fingers down, there is a grid of pins 3 rows x 6 columns. The jumper should be vertical between the pins 3rd column right on the lower 2 rows. If you received your riser and haven't moved the jumper yet, just move it left one pin. You can see an image of the riser here at mini-box.com
    I hope I added enough keywords that the search bots get this... I searched for weeks to find this info!!!
    Enjoy
  9. #49
    Mar 2005
    Pomona, CA
    Quote Originally Posted by srp365 View Post
    Enjoy
    So youve got 2 PCI cards hooked up now?? Cool!
  10. #50
    May 2006
    Calgary, Alberta
    Quote Originally Posted by farobaba View Post
    I want to upgrade to this board but I also have a M1-ATX. Is there a workaround for this issue?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  2. Replies: 5
    Last Post: 05-11-2006, 07:48 PM
  3. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  4. Micro ATX / Mini ITX (AMD, Intel, VIA)
    By wanjer in forum Newbie
    Last Post: 09-11-2004, 08:31 AM
  5. Replies: 2
    Last Post: 10-24-2003, 10:28 PM
