Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 62
Thread: Anyone try the Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
  1. #51
    Dec 2008
    Quote Originally Posted by Maheriano View Post
    I want to upgrade to this board but I also have a M1-ATX. Is there a workaround for this issue?
    would there be any problem using the m2-atx, or any of the newer psu that have came out ?
  2. #52
    May 2006
    Calgary, Alberta
    Quote Originally Posted by lancer0220 View Post
    Just the cost. It's the same price to buy a M2-ATX as it is to buy the motherboard.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  3. #53
    Vendor - Mo-Co-So
    Nov 2005
    Actually aside from not having a direct P4 CPU power connector (easily solved with a molex to P4 adapter or a little soldering) the M1 is superior to the M2 because of its higher output on the 5v rail (10A on the M1 vs 8A on the M2). Both the LF and LF2 are very power intensive on the 5v rail and use between 3.5 and 4A of 5V power. The 5V draw for a standard notebook hard drive is 1A and a notebook DVD drive is 1.5A, leaving you with just 1.5A before you are maxing the PSU out on the 5V rail. It should go without saying it but maxing anything out on a PSU is not ideal and will reduce the life span of the PSU.
  4. #54
    Mar 2009
    near Rochester, NY
    Yeah, but the M1 is only good for 2A on the 12V rail. Fail.
  5. #55
    Vendor - Mo-Co-So
    Nov 2005
    What do you need 12v power for on the LF board? It uses next to no power on the 12v rail! I would still rather have extra power for 5v USB devices then useless 12v power that is not used. But that is just my 2 cents.
  6. #56
    Mar 2009
    near Rochester, NY
    Lilliput screens are said to use around 10W, dunno if that is for the LCD or CCFL version but 10W is near an amp of 12V. The Atom processor itself has to draw something from 12V, otherwise they wouldn't have the P4 connector. If it draws the whole 8W TDP off 12V, that is max of another ~2/3 amp. I have an XM receiver which also draws power off the 12V.
    What would be really sweet is an easy way to add another linear regulator to the system to convert some of the excess 12V from something like the M2-ATX to 5V.
  7. #57
    Jan 2009
    Dallas
    Quote Originally Posted by sivart321 View Post
    So youve got 2 PCI cards hooked up now?? Cool!
    The pain was that even if you got it to boot with a certain jumper configuration, you'd even be able to find the device in device manager and load a driver, but the device wouldn't poll an IRQ correctly and malfunction. I did effectively try every jumper pair.
    I use a video capture card on slot 1 and a wireless card on 2
  8. #58
    Mar 2005
    Pomona, CA
    Quote Originally Posted by srp365 View Post
    Once you found the correct jumper location, all is well now?
  9. #59
    Jan 2009
    Dallas
    I tested it thoroughly. I had to. This is a production unit we install and support so it has to work. The machines run headless on a school bus and are accessed remotely 99% of the time through a wireless network. We did have to have the chassis' custom built for us.
  10. #60
    Jul 2008
    I've got this board, its still in the desk build stages (meaning I haven't ran it with my m2-atx yet) but so far it looks great, way better than my m10000.
  1. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 02:56 PM
  2. Replies: 5
    Last Post: 05-11-2006, 06:48 PM
  3. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 01:16 PM
  4. Micro ATX / Mini ITX (AMD, Intel, VIA)
    By wanjer in forum Newbie
    Last Post: 09-11-2004, 07:31 AM
  5. Replies: 2
    Last Post: 10-24-2003, 09:28 PM
