Results 1 to 5 of 5
Thread: m1-atx problems
    Oct 2006
    m1-atx problems
    Hi ppl,
    Just installed my m1-atx and via epia mobo into the case. The problems i seem to be having is that it won't always turn the mobo on properly (the fans come on but won't bleep, nothing comes on screen) whilst other times it does work fine! When the mobo doesn't turn on properly switching the ignition off doesn't work, i have to disconnect the supply all together and try again!
    As you can realise this is very frustrating and i dont want to install it into the car and find it doesn't work all the time!
    Is there anything i can do?
    Thanks!
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    the M1-ATX is a pretty weak power supply (it can only provide 2A on the +12v rail)... are you sure it can handle your system?
    Oct 2006
    my system (at the moment) is just the mobo, a hard drive (admitable a big 3.5" one) and a mouse and keyboard) i would think im asking too much
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by drummerian View Post
    Brand and model #'s?
    or is it a big secret?
    You mentioned in the op that the mobo is via, probably ok.
    3.5" hdd may be your problem. They use 12V. Try a laptop drive, which uses 5V instead to run.
    Are you powering the screen or anything else from the M1?
    ~Jimmy
    Oct 2006
    well, at the moment the hdd is some unbranded rubbishy (1gb one!! can you remember the days when we only needed this much space?) trust me, its only temporary!
    When i get my lappy drive, and a bootable SD i will see if the problem persists!
  1. M1 90w ATX
    By Imdbombboarder in forum Newbie
    Last Post: 02-06-2008, 10:43 AM
  2. XBOX + Apache v2.6 + M1-ATX = problems?
    By arionl in forum Power Supplies
    Last Post: 07-18-2006, 12:46 PM
  3. M1 ATX Remote voltage
    By thenick100 in forum Power Supplies
    Last Post: 01-18-2006, 09:59 AM
  4. M1 ATX + Centrino 1.5 Ghz + AOPEN XC CUBE MZ855
    By luckyno in forum Power Supplies
    Last Post: 01-06-2006, 10:19 AM
  5. M1 ATX, hangs. Help a swede in need.
    By Biograph1001 in forum Power Supplies
    Last Post: 11-18-2005, 10:01 PM
