Results 1 to 3 of 3
Thread: Help wiring battery isolator. Excitation terminal?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Got a free deep cycle, so I want to install it in the trunk to increase runtime of the carpc+stereo. I just won on ebay a surepower 95 amp diode based isolator.
    Strangely, the isolator has 4 terminals instead of the usual 3 on a diode based isolator. The extra terminal is a "excitation" terminal. I realize that some alternators have some sort of voltage sensing or whatever, which explains the need for this excitation terminal.
    So my question is... how do I find out if my car requires the excitation terminal to be connected? Can I just connect the isolator like normal but leave the excitation terminal disconnected? I am guessing that maybe the excitation terminal will tell the alternator to output a higher voltage to compensate for the voltage drop across the diodes?
    I have a 2002 mazda protege, but couldnt find much info on the stock alternator. The positive end of the battery has two large wires connected. I am guessing one is to the alternator and one is to the electrical system.
    Thanks.
    Aug 2009
    hello i as well have a 2002 protege mine is the protege 5 but we both have the same alt. i was wondering as well about the same issue as you just wondering if you went a head and installed the isolator or not
    i believe our alt is only 80 i have a 140v 3 stud isolator made by cole hersee co.
    and have not yet installed the system yet just wondering if yours worked ok.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Wow I made this thread along time ago, but I never did figure out what to connect the "excitation terminal" to, so I just left it disconnected and wired everything up like with a standard 3 terminal isolator and it works just fine.
    The voltage that my batteries sees is a bit lower now though, but if anyone knows if the Protege has some sort of excitation terminal that can be connected, Id love to know.
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 12:39 AM
  2. wiring question
    By the_realscott in forum LCD/Display
    Last Post: 10-30-2005, 01:54 AM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  4. time to a dead car battery?
    By chuckctv in forum Newbie
    Last Post: 08-24-2004, 02:47 PM
  5. Using Battery Charger in the House?
    By dug1967 in forum General Hardware Discussion
    Last Post: 05-14-2004, 10:55 AM
