Results 1 to 10 of 15
Thread: Problem with SB 24 bit LIVE USB
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Im not sure anyone else is having this issue, but I seem to, and its starting to bug me, I hope some1 can help.
    I have a KINO-690S1. The sound card is once again a SB 24-bit LIVE USB. When I turn on the PC sometimes, I hear nothing. When I go to the sound mixer area, it will say "no audio device is dedected", I then have to unplug the soundcard and plug it back in to get it to work...... what would be causing this issue, and how do I fix it?
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    thats odd.. i've had that sound card for over a year now and its been rock solid for me.. i havent had any problems other than the low output voltage. Sounds like there's a fault in ur device definitely.
    Live mp3Car Facebook Chat
    Dec 2007
    Mohnton, PA
    Quote Originally Posted by HiJackZX1 View Post
    I just picked up one of these over the weekend for 5.1 sound...and it installed without problem and is working fine.
    Jul 2007
    Miami
    I wouldnt be surprised if I have some type of issue with it.... my whole install has had so much bad luck..... i think maybe it may be the USB ports... Im going to try to connect it to one of my HUBS. i notice that when i connect certain thing directly to the onboard USB, I have issues. The sound card worked perfectly on my VIA, and for 5 months it sat in a drawer, waiting for the KINO.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Dec 2007
    Mohnton, PA
    I would not recommend running something high-powered, such as a sound card, through a USB hub. If it is a powered hub, it might be OK, but a self-powered hub, I wouldn't even bother.
    Jul 2007
    Miami
    Quote Originally Posted by phuz View Post
    Both 7 port hubs are powered, plus its simply to trouble shoot. if i have the same issues while on the HUB then i can assume its the Sound Card. If it doesnt act up, then something is wrong with the USB ports on the KINO MoBo. I really wish that i could use like an external power adapter to power the card. I notice that devices that are powered on there own, and or are low powered seem to work good on the onboard USB ports. i think its odd that a MoBo would have such advanced features and abilities, but then insufficient powered ports. You guys dont think I will have a issue with sound quality if running from the hubs?
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Dec 2007
    Mohnton, PA
    I only mentioned that because I tried to run my Stereo Sound Blaster USB card (not my 5.1 Live Card) off a self-powered hub, and it worked at first, but after about 1/2 hour, the quality started dropping. I unplugged it and threw it in a regular USB port, and it was fine.
    Powered hub? you should be fine for testing.
    Jul 2007
    Miami
    Do you think maybe it could be a com port issue? Is the SB assigned a com port? Maybe when i start up the PC there is a com port conflict and unplugging and plugging back in fixes the issue.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Jan 2008
    Southern Calif
    First off are you doing full restarts or are you hibernating? The usb soundcard is an audio device and not com port.
    I have a SB Audigy 2NX behind a 7-port hub and I would get the same thing as you, when I had my USB wintv stick plugged in and enabled. I rarely watch tv so i just disabled it on device manager and no problems with the soundcard showing up now.
    Jul 2007
    Miami
    i cant think of what may be causing it to crash, i have 13 devices connected :-(.... it does it in restart sometimes, cold boot, and hibernation.... I think maybe the device is damaged then :-(
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  1. USB DVD connection problem with XP
    By bes51659 in forum General Hardware Discussion
    Last Post: 02-10-2008, 12:15 PM
  2. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  3. Sound Blaster Live! Extenal 24 bit
    By ERIKbx in forum Classified Archive
    Last Post: 06-17-2005, 10:34 AM
  4. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 11:04 AM
  5. Sound Blaster/Vibra 128 vs. SB Live
    By magnetik in forum General Hardware Discussion
    Last Post: 06-17-2002, 01:37 AM
