Results 1 to 2 of 2
Thread: F_Audio Line In to Motherboard - Cable & Question
    Mar 2008
    Hi all,
    First the quick easy question, I want to hook up a 3.5mm audio line in jack to our VIA EPIA-EX series motherboard. In the manual there is this pic (attachment 1)
    I believe we want pins 2,6, and 10
    6=AUD RET_R
    Now the tricky part is finding the internal cable that is 3.5mm Female to individual jumper connector. I believe I have found something close here
    this cable will not work because the 3 pins on my mobo are not adjacent, if the connector was 3 separate connectors that would work.
    Does anyone know a good source of these internal audio cables? It looks as if i may have to scrounge the local electronics parts store or try to salvage parts from an old comp.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    the metal pins/terminals are removable, just release a tab on the side and they pull right out of the connector. if you have a 2x3, 2x4, or 2x5 connector from something else then you can use that instead (a standard 2x4 or 2x5 USB header connector will work). if you don't have one then you can buy a connector by itself (the website you linked sells them )
    alternatively, you can also use the terminals independently (without the plastic connector). just put some heatshrink over the terminals you want to use so they don't touch the adjacent pins.
  1. Noob Cable Question
    By AutoFX in forum Newbie
    Last Post: 11-11-2007, 09:34 AM
  2. Replies: 10
    Last Post: 08-28-2007, 11:10 AM
  3. Ribbon cable question
    By 96TransAm in forum LCD/Display
    Last Post: 09-05-2006, 12:30 PM
  4. Delco AUX Cable Pinout Fool question...Need Help...
    By gbrocker in forum General MP3Car Discussion
    Last Post: 08-29-2006, 07:17 PM
  5. audio cable question
    By daver in forum General Hardware Discussion
    Last Post: 10-04-2001, 02:04 PM
