Results 1 to 6 of 6
Thread: Power on by Windows Media Remote?
    May 2008
    Has anybody tried using a Windows Media Center remote to power on a laptop? I think this might be a very easy solution to the power on/power off problem, to mount my laptop under the seat, and run the IR reciever under the dash. Then, I think I might be able to power it up by pressing the power button on the remote. Has anybody tried this?
    Mar 2006
    Colorado, but Canadian!
    Nothing to say you cant as long as it supports wake from usb. And it would be power on, it would only work from S3.
    Also it wouldnt be as automatic and oem as a true SDC (shut down controller).
    1.9in x 2.9in -- 47mm x 73mm
    May 2008
    Yeah, but I don't know jack about soldering and electrical stuff, other wise i'd go that route. Is there any kind of SDC that doesn't involve wiring?
    Mar 2006
    You have to get to the power jack somehow. There is always a time to start learning.
    You could also do a WOL, but that involves even more soldering, just it is off-board.
    May 2008
    Yeah, somethin I've been meaning to get into. Just don't have the time right now.
    Low Bitrate kirk78h's Avatar
    Apr 2007
    Bel Air, MD
    Turning on a PC (or bringing it out of standby) with a remote is not as easy as it sounds. There is a lot of good information at thegreenbutton.com about MCE and remotes.
    Your laptop may have a feature in the BIOS to turn on when power is applied. If it does, then you only need something to put it in standby. There are applications using the serial port for this.
    Kirk
  1. windows power options disabled?
    By netman86 in forum Road Runner
    Last Post: 04-30-2008, 07:34 PM
  2. FS: $100 - OPUS 150 & Battery & Remote Control Power / Reset
    By fromplanetbob in forum Classified Archive
    Last Post: 02-12-2007, 06:49 AM
  3. VLC vs Windows Media Player
    By Kato in forum General Hardware Discussion
    Last Post: 04-28-2005, 01:50 PM
  4. Beyond Media out tomorrow!!!
    By Defiler in forum Software & Software Development
    Last Post: 12-04-2004, 02:27 AM
  5. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
