The
power wires are all linked, and the Audio is being fed using the amp outs on the xenarc connected to the proper ports on the harness.
I have the xenarc wired up to the harness, and the harness hooked to the car. Everything powers on and does what it needs to do. The problem I'm having is with audio quality. The audio is very quiet. With the stereo at half volume I get a really soft
sound. The audio is also very dull. Meaning I'm missing a ton of range. No low end at all, it's like my base is just gone. Everything is really muddled. Changing volume on the xenarc is really odd too, as I'm turning it down the audio does not progress quieter it seems to hang at one volume and then shift all at once. I don't know if this is a clue to the problem or just the way the unit works.
