Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: MPJA - MECI ASTEC DC-DC Converter
  1. #31
    May 2000
    Question
    I hooked up the MPJA supply to a 13.8 V 10A supply in my house, and it worked great with the computer. I then took it out to the car and hooked it up to the lighter socket. I tested the outputs and they were OK. I then connected the computer, and it destroyed the supply. Anybody have a clue as to what I did?
  2. #32
    Apr 2000
    seattle, wa us
    Post
    how do we hook it up to the motherboard? is there a pinout diagram i can look at?
    Luc
    Luc is offline
    Feb 2000
    Mamer
    Post
    Hi Trike,
    To hook it up just follow the previous post on this message, you've the schema for power outppput and just have to make it fit with your mobo.
    Luc
    Luc
  4. #34
    Apr 2000
    seattle, wa us
    Post
    follow what posts? i have tried hooking this thing up and am having no luck. when i stick a volt meter to the differant wires. they are all reading +12v.. even though as pin 10 states that it should be 5 volts. any ideas?
    Mar 2000
    Melbourne, Victoria, Australia
    Post
    Where can I get ny hands on one Dowunder?
  6. #36
    Mar 2000
    Question
    I'll try that again, this time in english.
    Where can I get my hands on one of these PSU's downunder here in Australia?
  7. #37
    Aug 1999
    Yorba Linda, CA
    Lightbulb
    Teninho -
    Sure you can split one of the +5V leads into two to give all your MB's +5V inputs power. Many motherboards merge them all when they enter the board anyway, so it's no big deal... I've powered a motherboard using just 4 wires (+5V, +12V, -12V, GND) and it worked fine...
    The main reason they use so many leads with the same voltage is for current carrying capacity. If you were a PSU manufacturer, would you rather run a fat, single 8 ga. wire or several 16 ga. wires? It's easier and more cost effective to use several smaller diameter leads to pass the current. Plus the connectors don't have to be massive, etc.
    Just some info you might find useful...
    --Jason
    Web site: http://www.m2pc.com
    Yahoo Pager: m2pc123
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    MPC Phase IV - *** PENDING ***
  8. #38
    Low Bitrate JesTa784's Avatar
    Jul 1999
    Cupertino
    Post
    Ok.. i'm one of the unfortunate that blew his power supply up too.. i'm thinking of either buying another or just going with invertor..
    Am i wrong when i connect all the +5v pins together and wire it off to the motherboard like that? is that why it blew up?
    I was acutally trying to run the dc-dc convertor off of a PC power suppy... is that another reason?
  9. #39
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi Guys well could u pls tell me as to what power supply are u looking at.. i mean the link pls
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  10. #40
    Low Bitrate got2liv4him's Avatar
    Oct 2004
    Gonzales, LA
    i think this post is over 4 yrs old, don't think those guys are going to answer, maybe...
    Kimi ga kawareba, Seikaimo kawaru!
