My "cookie cutter world"? Don't exactly know what that means. I don't want to get into the old "DC-DC Vs. Inverter" wars, but here goes.Originally posted by jshrieve:
If everyone lives in your cookie cutter world, then yes, DC-DC would always be incredibly convenient and without any downsides.
I don't know if you've seen the Arise supply or not (some pictures at http://www.aaroncake.net/projects/mp3player.htm ), but it is not a standard form factor. I don't know how big your supply is, but odds are the Arise supply is about the same size if you run your supply without a case and fan. Oh, and the Arise produces very little heat, so a fan is not necessary. One more part that can't fail.Nifty trick, considering I have a tiny non-standard formfactor power supply.
I had assumed that by "more work" you meant more complicated. That is the usual response.I didn't say 'complicated'. I said 'more work and little benefit to me'.
I haven't seen a picture of your space, but I would hazard a guess that the Arise supply will fit. Especially when you eliminate the large, bulky inverter.Work: either building or disasembling DC-DC power supply, to make it fit within the space I want it to fit.
Measure the output with a scope. Not that it matters. DC-DC is more thermally stable, and produces a stable output.More stable? No. My inverter is 100% stable.
Well, it does waste a small amount of gas, but more important is having the power available for other stuff, and not stressing the alternator with a 5A draw. The DC-DC idles around 1.3A.More efficient? Yes, but irrelevant, since I have 85+ amps from my alternator to waste (40+ at city stop and go rates, higher at freeway)
Sort of covered this above.Smaller? No. Not without disassembling and rearranging. BIGGER. The inverter about equalizes the space, but the inverter doesn't have to be physically with the computer and can thus be tucked away somewhere more convenient.
[quote]
Produces less heat? Yes, but irrelevant. I don't live in Texas. [quote]
With less heat, you don't need a fan.
The DC-DC runs down to 8V. The inverter stops at 11 or 10?Will run while car is being started: So will the inverter. Both solutions fail if your starter motor causes the voltage to drop too low.
You're lucky. Most people do.No noise? I don't get any with my inverter.
There are many circumstances when you would want to run the player with the car off. To provide toons while washing it, updating software, copying new MP3s, working on the car, demonstrations, leaving it on while at the mall so you don't have to wait for boot, etc.Running with the car off...paraphrased as it was lost in original quote
Not really.Larger.
Requires either building a PS or taking apart one to try and make it fit in the smaller AC-DC PS case.
But only slightly more then the cost of both the inverter and the standard PS.Double or more the cost of the inverter.
True.Can't plug other devices into it when necessary.
I don't get that one. Just use any number of standard connectors to plug into. Even a cigarrette lighter can be used.Can't easily unplug the computers without making a special plug or using a screwdriver.
True. But odds are that nothing will happen to it. The Arise DC-DC is manufactured to industrial specifications. PC power supplies are made as cheaply as possible.Takes a little longer to replace if anything should happen to it.
I don't particularily appreciate being called a "bum". I was simply trying to provide assistance. The DC-DC is best for most, but not all. We don't know the specifics of your setup, so providing a solution that will perfectly fit you is impossible.I don't deny that for many applications a DC-DC supply is better than an inverter, but not all applications are the same, so don't be a bum and try to suggest the same solution as being the best for all problems.
LinkBack URL
About LinkBacks
