Results 1 to 8 of 8
Thread: Two serial devices only one works?
    Variable Bitrate Stine161's Avatar
    Apr 2002
    Alberta Canada
    I have a memorex touchpad mouse and a Hewitt Packard fast remote with IR Both are serial. My computer has 2 serial posrts on the back but only one device can work both dont work at the same time. I have to go into the controll pannel and enable my touch pad but when I do that my Girder controlls shuts down and Vice Versa.......What am I doing wrong?
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Check the girder settings and make sure it's on the right COM port. If it starts up with the wrong port you may have to save the new settings and reboot...Does the touchpad work in the other port? Maybe a bad port? Maybe a dead IR reciever? Make sure your OS does not think the IR reciever is a mouse.
    Just a few ideas to try and help.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Apr 2002
    Alberta Canada
    well I have narrowed it dow to bboth girder and touchpad wanted to use com1 a quick bios change and girder was set on com2. all is good there but to get my touch pad working I have to go into the controll pannel and hit refresh twice before it picks up my touchpad...kinda odd....still trying to fix this....
    Jan 2002
    Temple Terrace, Fl.
    Updated software/drivers maybe? Reverse the COM ports the devices are plugged into...
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    Have you checked your IRQ settings?
    Jul 2002
    Boston, MA
    I think I am a tard because I couldn't get girder to work with my Creative slim remote and receiver from compgeeks.
    I can get it to recognize the remote, but trying to figure out how to make it do something in winamp is my problem...
    Anyone care to send my a copy of their girder remote config?
    -Mario
    Apr 2002
    Alberta Canada
    ok I changed the COM Ports (switched devicess) no new drivers are availble guess I have the newest one and still same problem.
    to m3rdpwr: goto www.girder.nl and download some exported groups for girder then load them you should be fine.
    Jul 2002
    Boston, MA
    Thanks man.
    They only had one for WinAmp 3 for the latest driver.
    But, I used it and modified it for WinAmp 2.x.
    I feel less like a tard now.
    Also, figuring out how to use some buttons such as on the creative remote so that I could go into mouse mode was a little tedious. Once I figured out that, it worked great.
    Thanks for the help and making me stick to it!
    -Mario
