For FM/AM u should consider getting HD radio.
hi
i'm looking for a TV tuner and FM receiver which i could plug in into the USB port as i've got all the others slots already filled with stuff..
maybe someone knows a decent device that will work with RoadRunner as well?
will this work?
http://www.hauppauge.com/pages/produ...a_pvrusb2.html
thanks![]()
why hd? i might not have the satellite option in my country
but are there any other USB tuners then (fm receiver built in too) ?
TV tuners typically have less than desirable FM antenna strength. Nothing like your HU.
cool. is there any with usb interface? or with usb tvtuner?
i'm still thinking about the usb FM/tv device.
i could use the car's antenna to get better reception? tv would be an extra..
The FCC has said that analogue signal transmission will stop in January 2009 (may have been extended) so why would you want to put all that money into hardware that picks up analogue signals?
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
ok. but which hd radio should i get then? is there a HD radio thread?
