Results 1 to 3 of 3
Thread: adding pci slots?
    May 2000
    Ft Gordon, GA
    Post adding pci slots?
    if i have a riser that has one male pci slot and several female pci slots can i hook it into a pci slot had use multiple pci cards?
    "if everything is under control, you're not going fast enough!"
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    That's a good question. I know such a thing could be done with ISA cards, but I doubt that it would work with PCI. The main reason is that IRQs are assigned by slot, not by card.
    Nov 2000
    Ventura, California, USA
    Post
    What I'd like to be able to get instead of a standard rigid right angle riser card would be a "riser" that would have both the male and female pci connectors with a flexible ribbon between. It would allow you to place the card anywhere you want to to save space and possibly help in removing any vibration induced problems (because the card would not then be at a right angle to the mobo) between the mobo/riser/card.
