Results 21 to 30 of 40
Thread: Carputer Cooling
  1. #21
    Jul 2001
    Intel little valley was running for me @ 65c under full load with no problems... it seems like a much more viable solution
  2. #22
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by Ces///M3 View Post
    Yes, lower power consumption lower heat generation.
    These are great things to consider and useful, but the original poster is concerned about operation in a car that is already HOT.
    The answer is reduce the temp in the parked car. Like txspazz suggests, keep the car cooler.
    TruckinMP3
    Read the FAQ!
  3. #23
    Jul 2001
    my point was really that the little valley runs pretty hot in the scheme of things (at least in my really small itx case... about 150 degrees hence maybe he could use that particular board or a board similar that can work up to a temp of 85 celcius
  4. #24
    Jun 2007
    St. Louis
    You can do a volt mod on the little valley board to drop the cpu voltage a little and reduce temps a bit more. I did the mod on mine and dropped load temps by around 7c. Dropped the voltage from 1.35v to 1.14v.
  5. #25
    Dec 2006
    College Park MD USA
    I just share the problem: I believe my last HDD was toasted by high summer in-car temperatures, and unfortunately I replaced it with an identical drive because I had it on hand. AMD Duron: rated 85C, M2-ATX: 85C, WD400BB HDD: 55C!
    I remember last summer the case temperatures were in the low 60's at times, at least one time it was 69C in the case. It's a slim (read: cramped, poorly ventilated) case and of course the M2-ATX doesn't have/need a fan, leaving only the CPU fan swirling air inside the hot case inside the hot trunk. I went and got a an 80mm case fan, but it's not very powerful and there's not many useful places to put it in the cramped case. I might go shopping for a smaller one or get creative with that case and the power drill...
    Similar, concurrent discussion of cooling methods here:
    http://www.mp3car.com/vbulletin/gene...ng-issues.html
    Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
  6. #26
    Jun 2007
    St. Louis
    I have the Travla C-150 case and it has **** poor ventilation by default. What I did was near the top (also front) is cut out 2 x 60mm fan holes and mount a couple high speed 60mm slimline fans. Works perfect and they move a ton of air through that little case. It's a bit on the loud side, but since it's in the trunk you can barely hear it in the cabin.
  7. #27
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Quote Originally Posted by WuNgUn View Post
    Did you say low power CPU? lol
    I yanked off a dual fan CPU cooler already from it...
    Going H2O isn't a LOT of money, is far more efficient, and just plan looks cool!
    Water cooling is great, makes for a nice, quiet, cool desktop PC. In fact, my desktop is water cooled, and is so quiet, the loudest thing on it is the hard drive....
    For a carPC, it's rather risky, and really unneeded.
    Why would I say risky? Well, whats the biggest problem with a water cooled PC? Leaks. Yes, leaks. In a desktop PC, you can use good barbed connectors, and nice, tight clamps, and not have to worry about leaks. In a carPC, you can use these same things. However, the constant vibration will eventually cause something to get a bit loose, and then you have your leak, and a short, and then quite possibly a nice little electrical fire.
    Un-needed, because you can make a nice powerful carPC using low heat components. use a mobile processor (I use a Core Duo, there are even better nowadays), and use a midgrade graphics card that doesn't put out a lot of heat, and you will have more processing power than you will ever use in a carPC.
    But hey, if you want to get all complex and run water tubes all around, and all that, to solve a problem that does not exist, have fun.
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  8. #28
    Jun 2008
    Phoenix AZ
    Thanks guys for all of your input, I have everything I need.
  9. #29
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    How about having a switch so that the PC doesn't turn on the ignition and then when the car is cooler (from AC or moving), just turn it on with the switch.
    Someone suggested measuring its current temp, I'd agree with that. See where your at right now before choosing a path...
    No solution is really going to get cooler than the ambient temp around the PC enclosure.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  10. #30
    Feb 2003
    SE Ohio
    Right now it sounds like the ambient temperature in the vehicle is the primary issue. As such I would perhaps suggest one of the solar powered ventilation fans that I've seen around (JC Whitney perhaps) that you stick the solar panel on your dash and it powers a small fan, enough to ventilate the interior and keep the car from getting stupid hot.
    As some else said you could also install Peltier coolers (on chip/die) that were watercooled to see more immediate results. Peltiers get cold/hot in a matter of seconds. However if the ambient temp in the vehicle is still beyond what the PSU will operate at modifying chipset/die/cpu cooling is a moot point.
    If you're not paranoid, then you're not paying enough attention. -kmfdmk.com
    http://www.mymp3car.com/MP3Car/PSUpower.asp
    1985 Supra 7M-GTE
    10.4" Planar LCD
    ECS GOAL3+ mobo w/ 512mb + 8GB sdhc
    Edimax EW7318USG Wifi w/ 7 db Ant.
    USB GPS
  1. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  2. trunk cooling
    By Jir1984 in forum General Hardware Discussion
    Last Post: 08-24-2005, 02:24 AM
  3. My Weekend of carputer hell!
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 01-05-2005, 09:19 AM
  4. Replies: 9
    Last Post: 10-23-2004, 03:25 AM
  5. Carputer Refrigeration
    By Maxis24 in forum General MP3Car Discussion
    Last Post: 04-19-2004, 07:14 PM
