Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: Carputer Cooling
    Jun 2008
    Phoenix AZ
    Carputer Cooling
    Anyone have any ideas on how to cool my carputer. It is in a 2004 Nissan Exterra and I live in Arizona. Right now the average temp outside is about 110 degrees. I'm affraid my carputer is going to just fry. I though about running a hose from my AC but when you first turn it on it blows air hotter than the deeps darkest parts of hell. If I crack the windows open the car isn't that bad but still around 120 degrees. I've looked into water cooling but the water would probably be just as hot as the air. So if anyone has any input it would be much appreciated.
    Oct 2006
    liquid cooling is best choice for you. Its big though, so expect a regular case.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by Punky View Post
    Why would you say that?
    Get the car running drop the cabin temp with AC, run the case fans for a bit then power up the PC.
    TruckinMP3
    Read the FAQ!
    Jun 2007
    St. Louis
    If you go with liquid cooling, I'd suggest hooking something up like a transmission cooler for the watercooling radiator, mount it up front - in front of the engine radiator, that way it's away from the engine heat, gets good airflow, and large enough to be used passively (for a lower wattage system). With a setup like this though, be sure you use large enough tubing with a good pump as it will need to push that water a long way possibly through a lot of bends which increase flow resistance.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Why don't you monitor the temperature of the PC with some temperature monitoring software? Right now, you think this is a problem. You don't actually know at the moment.
    I think the main issue is not 110 degree heat but the extreme 150+ degree heat builds up in the car. If the PC is mounted on the floor, though, you won't see that kind of heat. If it is inside the dash, it could be a different matter.
    Want to:
    FLAC WuNgUn's Avatar
    Sep 2007
    Water cooling mang...
    I'm starting my install soon...
    There are LOTS of rads available for PC water cooling...and you don't need it mounted out in the air stream...a couple of fans will work perfectly...
    Keep on eye out for my build pics soon!
    May 2006
    United Arab Emirates
    I don't think you should be concerned. I live in the Middle East and never had any problem with my car PC (mounted underneath driver seat). Hottest I have recorded on the car thermometer was 150F/65C. I have one outlet of the AC pointing to my screen to keep it cool.
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    Don't think its a problem, i had mine near the engine bay, and it could get real hot there, one time the pc, or the m2 switched of because of that. So it will switch off when it gets to hot, after cooling it down it works once again. I wouldn’t use the airco straight on the mobo, heat-shock is worse than high tempter
    _
    Mar 2004
    Little Elm, Texas
    thread moved....why this was in the forum suggestions/comments section I don't know....
    Jan Bennett
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    http://www.huperoptikusa.com/products_ceramic.cfm
    Most window tint places sell it. Cost is about twice as much as high end metallic tint.
    When you park, leave your AC in any position EXCEPT OFF or MAX.
    Use a small solar panel and a fan to blow air out the cabin vent (probably in the tailgate).
  1. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  2. trunk cooling
    By Jir1984 in forum General Hardware Discussion
    Last Post: 08-24-2005, 02:24 AM
  3. My Weekend of carputer hell!
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 01-05-2005, 09:19 AM
  4. Replies: 9
    Last Post: 10-23-2004, 03:25 AM
  5. Carputer Refrigeration
    By Maxis24 in forum General MP3Car Discussion
    Last Post: 04-19-2004, 07:14 PM
