Results 1 to 4 of 4
Thread: Good for bench testing??
    Low Bitrate Ricksastar's Avatar
    Dec 2007
    CT
    Hey everyone.. I am building my comp now in the work shop will this be fine for testing?
    http://www.autozone.com/R,NONAPP3042...ductDetail.htm
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    that looks like it should work for bench testing.
    I (like many other people here) have an old computer power supply laying around, so I just short the two pins on the ATX connector and use the 12V line on a molex connector to simulate getting 12V from a car battery.
    http://www.mp3car.com/vbulletin/faq-...workbench.html
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Quote Originally Posted by Stealth915 View Post
    Yep, thats the cheapest way to bench test, and works great. It's how I do mine
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by Ricksastar View Post
    A battery CHARGER like the one linked usually has a pulsing output; that works better for charging batteries. You want a constant output (more or less) instead of pulsing. You can use the charger but it is best if it is also connected to a battery for it to charge and then your battery will filter and smooth the output somewhat. Then you can run whatever off the battery while it is being charged, much like when your alternator is charging it. The simpler way like others have said on here is to use an old ATX supply or some other 12V regulated output supply.
    ~Jimmy
  1. Lilliput 629GL-70NP any good?
    By bmw328i in forum LCD/Display
    Last Post: 06-14-2009, 02:46 PM
  2. Replies: 8
    Last Post: 02-25-2005, 01:32 PM
  3. Question on good MB for suspend modes.
    By tsm_man in forum Newbie
    Last Post: 01-12-2005, 06:51 AM
  4. Are these a good LCD?
    By mainfraim in forum LCD/Display
    Last Post: 05-18-2002, 06:37 PM
  5. Testing a power supply to see if good or dead?
    By Squeezer in forum Power Supplies
    Last Post: 03-17-2002, 01:19 PM
