it looks sweet, but remember sata cable is suppose to be max of 1 meter long, and esata is 2m.
unless you're looking for the hard drive as storage, its kind of pointless to have removable HD that has an OS installed.
I was wondering if i put a hard drive inside of this enclosure and connect it to my carpc via sata off the motherboard using the ezswap, will it allow me to boot from it like a normal harddrive? I like this item as a mounting solution also because the fact that you can put the ez swap anywhere in the car granted the wires reach and you can just eject your harddrive.
http://directron.com/mrk250st.html#caption
not really especially if you use your car to datalog. It has a usb connection all you need to do is eject the drive and go and connect at your house via usb and you can explore the files. I dont plan on moving it more than a meter away though.
