Results 1 to 6 of 6
Thread: Touchscreen causing bios to stall?
    Newbie nemoid's Avatar
    Jan 2008
    914.ny
    So I am running an Artigo Pico-ITX kit for my CarPC. My problem is that when the computer starts up, it stalls (for about 30-60sec) at the "IRQ Device Listing" page during the bios boot, right before windows starts up.
    I know the stalling is related to the touchscreen (Lilliput EBY701), because when it only stalls when it is plugged in. If I disconnect it, the computer will boot immediately, like it should. If I disable USB from initializing at all, the computer will start immediately, but then I have no USB devices.
    Anybody have any clue as to what is causing the stalling and how to eliminate it?
    Oct 2006
    couldn't u disable IRQ in bios?
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Few things:
    Is your sreen running on regulated or unregulated power and is it grounded properly?
    Try a different USB port.
    Find out what IRQ number is hanging and move it to a different number. This is more advanced and you will want to be sure of what you are do.
    If you disable IRQ, nothing will work in Windows.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Jan 2008
    914.ny
    I don't plan on disabling IRQ.
    The screen is running on unregulated power. Yes, it is grounded properly.
    I will try another USB port when I get a chance.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Also might want to try a usb hub. It might just be a partial incompatibilty. Seen similar things with a Dell server that would lockup on POST if I had an external HDD hooked to the machine. Putting a hub in between the two fixed it.
    Tidder
    Try RevFE
    Jan 2008
    914.ny
    It seems that switching the USB port has solved the problem. *hopefully*
    Something so simple... Thanks a lot guys
  1. Replies: 14
    Last Post: 04-13-2007, 02:23 PM
  2. Problem Identifying Touchscreen Controller
    By yingyang006 in forum Input Devices
    Last Post: 01-08-2007, 10:01 PM
  3. Motherboard and Touchscreen don't love each other...
    By kevpriest in forum General MP3Car Discussion
    Last Post: 07-27-2006, 10:25 AM
  4. USB Touchscreen Problem
    By skeeter007 in forum Input Devices
    Last Post: 10-07-2004, 03:49 PM
  5. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
