Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: pico itx
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    pico itx
    is the pico itx board good enough for a car pc system?
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    If you don't need S3 sleep then I think is good enought for normal user...
    Jul 2006
    seattle
    Depends on what you want from your carpc, but like dejan said, it should be enough for most normal user.
    And also too expensive for most normal user
    Aug 2007
    Queens, NYC
    Quote Originally Posted by _Dejan_ View Post
    what's s3 sleep? I was thinking if something like a c7 processor. Like the 1.5 ghz c7...something along those lines
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by chris350 View Post
    Option like S1 but with a lot of lower power consumption... Check on google... VIA pico doesn't have C7 processor If I remember it have Eden... I was test it(have it) with 1GB DDR ram but is slower than NX15000G(you can fell diference)...
    Aug 2007
    Queens, NYC
    ok how about a stage one or two from the mp3car store ? For music and DVD play, gps nav. too ......? Those sound good to me.
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    I can't tell about this products a lot, but In my first CarPc Im using Jetway VIA C7 1.5GHz (Like in stage2) and work ok except S3 sleep which it don't have it... For Stage1 I can't tell nothing because Im not test it...
    Aug 2007
    Queens, NYC
    why is s3 sleep so important? What's the difference with s1 and s3? Please explain
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    s1 basically just puts the processor to sleep. s3 kills pretty much everything except ram. Power consumption mostly. S1 will kill the battery just about as fast as having the machine on and playing music. S3 could standby for hours before draining the battery with the car off.
    http://www.yafla.com/dennisforbes/On...umppo-exe.html
    Tidder
    Try RevFE
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    When you go into S1 board will take you around 10W, when you go into S3 board will take around 0.5-1W. In S1 CarPc will work around 1-3days(depend of battery) in S3 will work much more before will "empty" your battery, but if you will use hibernate function then this is not so important...
  1. New VIA Mobo 1/2 the size of Nano-ITX
    By legacy05gt in forum Hardware Development
    Last Post: 08-12-2008, 08:52 AM
  2. Mini ITX or Micro ATX
    By Dragonknell911 in forum General Hardware Discussion
    Last Post: 10-19-2006, 09:19 AM
  3. Trying $145 Migrus P4 itx for second install
    By VehicrossPC in forum General Hardware Discussion
    Last Post: 02-25-2006, 10:03 PM
  4. Nano ITX in an Evo
    By SAScooby in forum Worklogs
    Last Post: 12-06-2005, 04:54 AM
