How much was the drive and where did you get it?
I just acquired an 800MB IDE flashdrive, threw windows 98 lite on it, and it boots on the Epia-M in 17 seconds (from poweron to fully loaded). Not too bad I'd say but it didn't floor me either.
2001 740Il - Jet Black with MkIII and more...
Was it a IBM microdrive? 17 seconds is pretty good, 98lite still isn't the fastest booting os
I got it on ebay. It is a silicontech IDE flashdrive. I would like to boot XP embedded off it but ...
Ive got a 64mb compact flash card connected as an ide hard drive. It doesnt really boot any quicker than a standard hard drive. The IDE interface is the limiting factor these days, not the drive speed.![]()
(=========-) 99% complete
AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
All jammed in external CDROM drive case.
Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
so which would boot faster? an ide flash drive or a firewire hard drive? or is the firewire still limited by ide ?
That isn't true at all. Some modern drives can run at burst rates up to about 50MB/s, which is half the speed of ATA100. Most of those rates are when it just has to read a contiguous section of the disk, which is not what is happening on boot up. Many people here are using notebook HDs, which are even slower.Originally posted by phil.45
Going to a flash based disk is a huge speed boost, though you have to worry about things like the limited number of write cycles allowed (100,000), so you would probably need a normal HD for window's swap space.
Twostep
Most "firewire" drives are actually IDE disks with a firewire converter. So at best, they would perform the same as an IDE drive alone. The one advantage they have is that firewire requires much less CPU time than IDE, so if you have a slow machine (with firewire, which doesn't seem likely) you might see some speed benefits to firewire.Originally posted by az1324
Twostep
Us EPIA-M owners fall into this boat...Originally posted by Twostep
...so if you have a slow machine (with firewire, which doesn't seem likely)...
Twostep![]()
How would firewire take less cpu time than ide? I was under the impression ATA overhead is lower than firewire (firewire is more concious of error correction than ATA).
I would definately think compactflash would be fastest as long as it's rated for higher speeds. CF card speeds can vary by a factor of over 16 times.
