Results 1 to 6 of 6
Thread: Splicing USB ports
    Dec 2007
    Reading, PA
    Splicing USB ports
    Well, I googled it for about 20 minutes and found nothing. I went onto IRC - EFNET in #windows and those guys are assholes. Apparently they would rather spend 10 minutes of their pathetic lives telling me that I should google all day long until I find it instead of taking 30 seconds to tell me what I need to know.
    If I have two USB devices, can I splice the lines together into one cable, or does it NEED the hub for some type of frame-switching?
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon
    I don't know the definitive answer, but logically, you would need a hub. Once you splice, there is no way for the computer to define individual devices, is there? With a hub, the computer has to see the hub first, and THEN decide the other components. Plus, there are some really cheap 4 port, 2.0 hubs out there. Just go that route and be safe. I think the splicing plan could cause some serious problems.
    My opinion is my own.
    Dec 2007
    Reading, PA
    Quote Originally Posted by danielkh View Post
    I figured the HUB did some intelligent switching, but the only reason I don't want to use the hub is I am trying to keep the area behind my touch screen clutter-free, and didn't really want a hub back there. I have a 15' foot USB cable run from the PC to the front, which is now connected to a (semi-working) 4 port hub.
    I thought it might be too good to be true.
    Sep 2007
    Beaverton, Oregon
    Have you seen these? I also wouldn't go with more than a 6' Usb cable unless your hub is powered, and then I would still stay with 6' if possible.
    http://cgi.ebay.com/NEW-4-PORT-HIGH-...QQcmdZViewItem
    I know there are those Belkin (I think), 16ft non-powered 2.0 USB cables, but we used them on our equipment at work and never got 2.0 out of them.
    Dec 2007
    Reading, PA
    I don't have a choice. I need a 15' cable to safely route the cable from the PC in the trunk up to the dash, where I added 2 custom ports. If I must have a hub, I will build a 5vdc power supply for it.
    BTW, just bought that hub
    Sep 2007
    Beaverton, Oregon
    You know, there might be a plan b if you don't want the hub behind your touchscreen. Put the hub somewhere else. Say 2-4ft from the Touchscreen. Then you can run standard usb cables to whatever you need the hub for. On my system, early on, I had the hub in the console so I could use it for more "stuff" if needed and it did great.
  1. interesting way to install XP on cd-less/floppyless
    By gospeed.racer in forum Operating System Optimization
    Last Post: 11-11-2010, 06:55 AM
  2. Extra USB Ports
    By mdlesk in forum General Hardware Discussion
    Last Post: 03-19-2007, 05:51 PM
  3. Extra (hidden) USB ports on Laptop?
    By Nerd2 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 03-12-2007, 04:07 AM
  4. WTB: USB Ports morex case
    By hoodlum in forum Classified Archive
    Last Post: 03-02-2007, 05:17 PM
  5. DSATX 220 review? will it shut down USB ports?
    By chewEboy in forum Power Supplies
    Last Post: 06-04-2006, 06:56 AM
