Which Line Level Out To Use On Audigy2?
ok, i need to connect one of the outputs of the audigy2 card into the aux input of my HU (which is a left and right RCA connection) The ouputs on the sound card are, digital out, and it has 1,2,3 labled outputs. Do i need some sort of mini jack (like a headphone jack) to RCA cable? If so are there ones that go from the mini jack to left and right RCA? in other words a "Y" cable?
Or is there an easier way to connect the sound card to the head unit?
Comp. Specs:Shuttle SS40G, Athlon XP 1700+, 256MB DDR, 40GB HD, Belkin Desktop 802.11b card (good range), SB 128 sound (onboard is a bit noisy), DVD ROM
Toshiba 100CS laptop, P75 40mb ram, 550MB HD, Megahertz LAN/modem PC card, modified to run off 12VDC
Other stuff:Generic USB hub & USB to serial adapters, BS2SX power control system w/battery buffer, Jazz 300W Inverter, FM Modulator, Palm Vx, & GPS
Status: 80% complete (Almost done with the controle boxes)
alright i just bought that cable, now to i connect the mini jack to the digital out, or one the three other outputs?
Output 1 probably. The digital one is used for things like surround sound processors.
alright cool, i am gonna try hooking it up tomorrow and see how it sounds, thanks for the help
You use output 1.
Outputs:
1-Front Left and Right
2-Rear Left and Right
3-Center front and Rear, Sub.
Digital - Use for hookup to Creative 6.1 Speaker set.
-Drew
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
