Results 1 to 8 of 8
Thread: PC Chassis Ground
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    PC Chassis Ground
    I don't plan on using a case for my pc, but rather a rack-like setup with everything either mounted to some sheet metal or wood in the compartment in my trunk, havent worked all the details out yet.
    I'm worried about grounding I guess... Do I need to mount everything to some sheet metal (ie.. the mobo standoffs, the HD Radio case, the m2-atx, hdd) as a common ground? Or can I just mount them to anything, anywhere and make sure the ground leads from each piece of hardware goes to a common ground on the car chassis? and not worry about the components chassis?
    Hopefully that makes sense
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Your Motherboard should have a good ground through its connection to the power supply (ATX 20/24 pin). All peripherals will then share the motherboard ground. So you should be good with your rack setup, just make sure the power supply is grounded properly.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Jun 2008
    Relatively new to the art of installing a computer in a car, though mine is in and running, but I have been building pcs and using... alternative cases for years.
    There is often talk of the need for motherboard grounding and suggesting it be grounded in common with a psu and psu ground line (ac cord ground typically) but-
    The ONLY cases I have seen this really seem required are with high-powered external video cards. (And even then I wonder if it is due as much to an existing motherboard fault.)
    I have never seen it be an issue with integrated graphics or "weaker" video cards.
    I didn't bother with my system, which has an ATI 9200, nor would I bother doing it with ANY system unless it has a video card with a molex for power.
    (My system is housed in a non-conductive box and the only ground it gets IS through the power supply.)
    Constant Bitrate funkyphil's Avatar
    Sep 2007
    CHI-TOWN
    Smile my two cents
    I have attached three pics on how I have installed my motherboard. I have it on the back of a board that is placed in the hatch of my car. The actually MB is screwed to a cut out of an old computer case. I believe this would be ok to have the correct grounding, however I am no pro yet. But again my carpc is working pretty well and has been for about 6 months. Please add some advise if anyone thinks the way I have mine is not a good I deal!
    Thanks Phil
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    i had no, and i have no case in my previous (Octavia) and current (Astra H) car, and there were no problem with them any time...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Mar 2008
    Ripon, CA
    Thanks guys! Exactly the answers I was looking for!
    Vendor - Qube colin's Avatar
    Dec 2006
    FPeter, sick installs. Very nice low profile!
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    FPeter, i guess if you have room to put it there. DAMN! Crazy.
    roflcopter,
    Anyways, For noise, proper grounding too all parts would be advisable. My home pc audio sometimes will get noise if my VGA cable is too close to the speaker wires. not that i dont have a huge rats nest of cables and connectors shoved under my desk
    My Alpine stereo will have noise on the aux if my epia MII12000 pc is off. i think my audio ground is not the best and i only get good ground once the pc powers up.
    Anyways good to be thinking about it for your design. I would ground the motherboard grounds to something. You will find out right away if you dont have good grounds and your video or audio have static. Good luck.
    again crazy place FPeter
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
