Thanks for the photos! This is great.
Would you be able to take a high resolution photo of where the power button connects to the motherboard? it would be really nice to have the p2140 or the p1900 be able to control the on off state of the computer based on ignition status of your boat or car.
There are tons of adapters out on the market for dell laptops. There are a few drawbacks to using one of those with the dell studio:
All of these issues are solved by the p2140 and the p1900. (shut down time, low voltage, auto shut down)
- There is no built in battery on the dell studio. If your cig lighter is ignition switched it will immediately kill power to your PC causing a hard shut down.
- If your cig lighter is not ignition switched and you forget to turn off your pc you will have a dead battery.
- No auto shut down (as I mentioned above)
Good luck with the install.![]()
LinkBack URL
About LinkBacks
