Results 1 to 5 of 5
Thread: 99 Passat radio AM won't come in
    Jul 2008
    My 99 Passat radio won't play on AM and not so good on FM. I think the antenna or antenna wire is defective. How do these get the antenna out? Thanks. rchild@rochester.rr.com.
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Do you have an aftermarket stereo in your VW? If so you need to get a powered external antenna adapter for it. Check out www.enfig.com good guys over there.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Jul 2008
    99 Passat radio
    It is the stock radio.
    Feb 2004
    Florida
    Yeah your headunit might be defective then. Check out the classified forums on forums.vwvortex.com People are always selling their stock units there cheap.
    '02 GTI
    Jul 2008
    99 Passat radio
    I'm pretty sure it's the antenna wire. Is there an easy to take off the roof antenna? I ordered the radio remover clips to take out the radio and check from that end.
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. Delco Radio Swap for another Delco
    By novice in forum General Hardware Discussion
    Last Post: 05-31-2008, 08:10 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. need radio help
    By anniechick in forum Car Audio
    Last Post: 04-09-2007, 11:54 AM
