My setup has a 4 gauge wire running from the front to the back. In the middle of the 4 gauge wire is a circuit breaker and a splitter that has a 8 gauge wire for the PC. All though this is a laptop i assume, i would avoid using a inverter, they are not very reliable. If you still decided to use the inverter, I think the way it works, is you have the 12v (4 gauge) to the inverter 12v then the other to ground. Then the inverter should also have a remote wire which would go to the radio harness ACC wire. If it doesnt have a remote wire, then you would use the relay........
acc would go to one side, then the other to the ground.
then 12 V to one side and other side of relay to inverter.
If you are wondering how to connect the 4 gauge to the relay, i would use a distrobution block.Code:12V --------------- - O - - - ACC----------- O O ------------ TO GROUND - - - O - --------------- Inverter
LinkBack URL
About LinkBacks
