Results 1 to 3 of 3
Thread: Motherboard Mounting
    May 2008
    I've mounted my ITX and I was wondering if I may have a problem.
    The board is mounted to dark plexiglass with a 1/2 inch spacer for air circulation.
    I don't guess the Plexi will cause a heat problem?
    Calvin
    Elsewhere
    No.
    How about the Wiki?
    Jul 2008
    Tucson, AZ
    No, but plexi, and most "plastics" can build up static AND attract quite a bit of dirt/dust, both of which can be bad for your electronics. The only other problem COULD be that of grounding, since quite often the chassis is a common grounding point for the various parts of the board (each standoff is a ground point, which may or may not be critical to your board, depending on the design). I haven't really looked closely at my mini-itx board yet to see if this is the case, but in SOME boards (for other electronics) it is important to use all your mounting screws on a metal chassis for proper grounding.
    Just something to consider. If nothing else you can run a cable to each screw/standoff if it turns out to be necessary.
  1. MTB-057 Intel D945GCLF Mini-ITX Motherboard OS Installation problems
    By Fiberoptic in forum MP3Car Products - store.mp3car.com
    Last Post: 07-08-2008, 02:50 PM
  2. Mounting a 700tsv
    By ninjatill in forum LCD/Display
    Last Post: 10-07-2005, 12:47 PM
  3. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 01:00 AM
  4. Which Motherboard to Choose
    By james33440 in forum General Hardware Discussion
    Last Post: 06-07-2005, 11:35 PM
  5. Mounting a motherboard
    By mjohnson in forum General Hardware Discussion
    Last Post: 08-31-1999, 10:53 PM
