Results 1 to 3 of 3
Thread: connecting 3 screens to PSU, how do I do it?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    sorry for the non caps, im on my carpc. i originally set up my screens to turn on and off with the ignition for the reverse feature, but i decided to use a system dedicated to reverse. one anoying thing is that when i turn off the car you hear the touchscreens disconnecting from loss of power. i want the pc to control the power now. do you think its safe to connect all 3 EBY701s to the 12v line of were a molex connector device would go on the psu? currently i have one screen and the 6 cooling fans for the pc. will 3 screens and 6 fans be too much?..... the psu im using is a opus 320. thanx in advance!
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Constant Bitrate cMags's Avatar
    Jun 2005
    Marietta, GA
    You'd have to crunch out the numbers for the max current available on your 12V rail, and see what devices you have pulling from it (max). If you have a spare 2 amps, go for it. Each EBY701 pulls about 1A.
    That said, my M2ATX 160W is running my M10K, 2 full USB hubs, and EBY701 w/o a hitch.
    CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
    Jul 2007
    Miami
    Thanx for responding, I thought the EBY701 uses 1.5 amps? I think I may take the case fans off of the PSU and have them connected to the relay. Only the processor fans would stay on the PSU. I know there was a thread on here that had PSU ratings but I cant find it.....
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  1. Fan placement on case and screens!
    By HiJackZX1 in forum Fabrication
    Last Post: 06-04-2008, 07:12 PM
  2. 650W PSU blew up my dual XEON setup
    By Chris31 in forum Off Topic
    Last Post: 09-23-2006, 08:55 AM
  3. So how do I get the PSU to turn on on ING?
    By Emo in forum Power Supplies
    Last Post: 03-28-2006, 04:49 PM
  4. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 12:04 PM
  5. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 01:08 AM
