Alphared, are you sure its IDE? Generaly, IDE is 40-pin, SCSI is 50-pin. Although, I know that sometimes laptops do things "wierd".
Dex
For a Internal Laptop DVD with a 50 pin IDE, is it possible to use the hard drive conversion adapter to change it to 40 pin IDE?
Dex
50 pin is the 40 IDE pins plus power and sound...
if you search the forum you'll find adapters for laptop cd/dvd drives
Vickumar used to have 'em, I don't know if anyone else does. I know for certain www.caseoutlet.com does.
aka Kumaneko
"Don't make me moderate your ***!"
Maxima of Doom - project thread - photo gallery
mp3car system is currently FUBAR and finances do not allow for a correction of that situation
Real computer hackers use a rotary cutting tool on their motherboard.
most likely...Originally posted by Alphared
generally, the connections on the 50 pin are set up so that the 40 pin ide connections are as they are on a normal HD, and the remaining 10 pins are for power, audio, and possibly drive selection (master/slave).
you will need to hook up the power to the drive, and unless the drive is digital audio compatible, you will need to hook up the audio as well.
~mike
Single Member of the "1000 Post and No MP3 Car" Club
PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
2000 Cavalier Z24 [###-------] Only 30% Done ... Still
well this is the DVD adapter
http://cableclub.com/view_product.asp?item_no=99663
which doesn't fit. The back of the DVD looks like the back of the harddrive.
so I was referring to this:
http://cableclub.com/view_product.asp?item_no=99680
aka Kumaneko
If your DVD player doesnt have a JAE 50 pin connector visible (standard laptop cdrom), then it probably has a custom adapter screwed in over it. I ran into this when I was looking into using a salvaged eMachine eOne slim cdrom drive that had such a adapter screwed to the drive. Removing the propriatary adapter revealed the common laptop cdrom connector.Originally posted by Alphared
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
