Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Quick Question: 800x480 support on Intel D945GCLF?
  1. #21
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    your suspicion is correct. post has been approved.
  2. #22
    Newbie sovicka's Avatar
    Aug 2008
    Prague
    Carputer based on eee box pc.
    Current status: moving! Older carputer version: photo I | photo II
  3. #23
    Aug 2008
    Quote Originally Posted by sovicka View Post
    Useful, yes, for special screen displays not supported by the BIOS. But if there is a way to support the needed resolution using the BIOS instead of a driver, I would always prefer that. Drivers only work within the OS they are intended for, and there are some folks who may want to run, for example, Linux on their system with an 800x480 display. Yes, Carft does have a Linux driver, but it requires a separate installation.
    Also, I don't see the Intel D945GCLF board on their list, even though the D945G chipset is listed (and that's the northbridge chipset used on that mobo). That is probably not important and only means that Carft doesn't sell the Intel motherboards.
    Every approach has advantages and disadvantages, but I always favor a BIOS-based approach if it is available, just because it keeps the overall installation simpler.
    RickD
  4. #24
    Apr 2007
    So has anyone successfully tried the BIOS and got it working? I flashed it and I can still only get 800x600 as the lowest resolution.
  5. #25
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    Quote Originally Posted by cloud_171 View Post
    try the " display properties > advanced > adapter > list all modes " option
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
  6. #26
    Aug 2008
    Quote Originally Posted by FPeter View Post
    Yes, that works for me also, using BIOS version 099. But the sequence on my machine is "Display properties > Settings > Advanced > Adapter > List All Modes". Then, select 800x480. Some displays may not correctly report their supported modes to the plug-n-play process in XP, which requires this additional step to look at the all the modes supported by the BIOS. I am able to display this resolution on my 800x600 monitor using this procedure, even though the monitor ostensibly does not support it (it letterboxed the display).
    But as I understand it, it does take the more recent BIOS versions to provide this resolution.
    RickD
  7. #27
    Aug 2008
    One more item for posterity:
    The AOpen CD/DVD, which shares the same IDE cable with the Addonics Compact Flash adapter, would go away when in XP after a while, which in turn caused Explorer to crash when attempting to access the CD and would also cause the CD drive to lock up, usually when spinning, such that the drive would not open.
    The cause is apparently a power management setting within XP. I had power management set to power down the disk drives after 10 minutes. I set that parameter to "never" and things seem to be working now. My assumption is that either the CD/DVD combo drive does not support APCI. Removing the CD, however, effectively powers down the drive, saving a watt or two.
    RickD
  8. #28
    Jun 2008
    Illinoise
    I installed the updated bios "099", tried the "show all modes" option. Still no 800x480.
    Got audio tho. It took a fresh install of XP home SP2 to get it to work. I have to say that the realtek HD engine on thsi little board is pretty kick a55! The sound on the Bose premium system stock in my 05 Murano is comaparable to cd quality with high bitrate MP3s.
    What to do with my now open pci slot............ still would like a decent video card with an s-video out so I could have dual displays, and/or front touch and rear dvd set-up.
  9. #29
    Apr 2007
    Quote Originally Posted by rickd View Post
    RickD
    Thanks guys, got to check that out tonight then!
  1. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  2. 800x480 V8000 BIOS & Driver from VIA GmbH Support
    By ShawJohn in forum LCD/Display
    Last Post: 12-08-2004, 04:02 PM
  3. Replies: 3
    Last Post: 10-22-2004, 12:09 AM
  4. Replies: 2
    Last Post: 10-20-2004, 08:09 PM
  5. Xenarc 700TSV 800x480 Support
    By auto_robotics in forum LCD/Display
    Last Post: 08-27-2004, 01:33 PM
