Page 35 of 69 FirstFirst ... 252627282930313233343536373839404142434445 ... LastLast
Results 341 to 350 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #341
    Mar 2008
    Australia
    How can I change the Intel splash screen that comes up while booting? I just want it to be plain black. I downloaded the Intel integrator toolkit but I don't know where my bios files are located, so I cant open it and edit the image.
  2. #342
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Quote Originally Posted by quix View Post
    I booted and installed from a usb powered dvd-rw.
    It is possible, it just takes a lot of tries to get the timing right so the drive is actually on by the time the bios queries the device.
    I've done two setups now using this board and a usb optical drive. Worked fine, first time.
    Quote Originally Posted by blade828 View Post
    You will need to download the latest BIOS revision from the Intel website and open that with the toolkit. You can't pull the BIOS from the machine with the toolkit to be edited.
    I installed my carpc into my pet Kangaroo, mate.
  3. #343
    Variable Bitrate Deric's Avatar
    Sep 2006
    Easiest thing is to download the Bios files from intel.
    You will have to use the following file
    Iflash BIOS Update / Integrator Toolkit BIOS Files [LF94510J.86A.0140.BI.ZIP]
    See the link here
    http://downloadcenter.intel.com/Deta...ndent&lang=eng
  4. #344
    Mar 2008
    Australia
    Quote Originally Posted by NiSlo View Post
    Thanks mate, Is there a particular size the image needs to be? I run my screen at 800x600
  5. #345
    Sep 2006
    Glad you got it to work. I did see an update on the BIOS notes in November that said it fixed an issue with USB drives not able to boot
    Quote Originally Posted by pdriver View Post
    It's interesting as my IDE ribbon also has exactly the 'break'. So maybe not a fault? I agree, seems quite odd though.
    Any how I thought I'd try one more time before getting on the blower to intel. Here's how it went...
    First I tried connecting my USB DVD to my Acer Aspire One netbook to double check that the drive is working correctly. Coincidently my Acer has the same Atom cpu and very similar motherboard, which could give further clues regarding compatibility. The USB DVD works and my netbook booted straight into Windows XP installation. Nothing is wrong with the external drive therefore.
    Back to my carputer build. Same as before, nothing happens and machine will not boot to external drive. One last attempt before getting on the phone. I CTRL ALT DELETE instead of powering down the psu and hey presto we're into windows setup. I don't know why or how this worked - I had tried the same thing a number of times previously.
    So windows has nearly finished formatting my HD and it looks like we're in business. Watch this space.
  6. #346
    Variable Bitrate seninha's Avatar
    Dec 2005
    Holland
    Quote Originally Posted by veronicathecow View Post
    Boot times are always too slow so I made a comment to the Intel team re boot speed and they replied
    "Thank you for contacting Intel Technical Support once more.
    We are glad to hear you we were able to answer your questions. We also appreciate the feedback regarding "Linux boot and a general faster boot". We will take it into consideration."
    Perhaps if enough people contact them they will address this problem
    All the best
    Tony
    I also contact them about the slow boot issue,but never got any responce.
    My slow boot problem is comming up when I use the PCI slot.
    When I remove my ATI VGA card systems start 's up in 25 seconds.
    Can you give me a link where you placed your request??
    Gods right foot!!
    Renault Grand Espace 3.5 V6
  7. #347
    Nov 2007
    Clearly there is a problem with USB drives but I also had
    similar issues with several IDE drives.
    Glad to say I have everything installed now but not without quite a bit of hassle. Many thanks to everybody that helped me out.
    Paul
    UK
  8. #348
    Jan 2009
    Hi Seninha, you need to go here to email tech support at intel
    http://supportmail.intel.com/scripts...ome.aspx?id=36
    All the best
    Tony
  9. #349
    sdh
    sdh is offline
    Jan 2009
    Has anyone managed to use the TV-Out functionality for second monitor connection. Which ping on the connector has the Composite Video output. Please guide.
  10. #350
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    Updates to first post.
    I updated the first post to answer the above question as it seems to be recurring and it vexed me for a while to.
    If any of you who have learned the ins and outs of this board, have anything you feel should go in the first post, send it to me in a PM and I will update it.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 09:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
