Page 36 of 69 FirstFirst ... 262728293031323334353637383940414243444546 ... LastLast
Results 351 to 360 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #351
    Newbie miko55's Avatar
    Jun 2007
    Ljubljana, Slovenia, Europe
    Quote Originally Posted by sdh View Post
    Has anyone managed to use the TV-Out functionality for second monitor connection. Which ping on the connector has the Composite Video output. Please guide.
    Answer from Intel:
    Hello Miha,
    Thank you for contacting Intel(R) Customer Support.
    As far we understand, your 4 pin Composite TV works when it is plugged in directly to the motherboard, however, it is not recognized if you use a RCA adapter. Bear in mind that adaptors are not supported.
    Unfortunately, we cannot garantee full compatibility with all this kind of devices offered in the market.
    We recommend contacting your system manufacturer or system vendor for information on the TV-out capabilities of your system. Also, we do not recommend the use of any type of converters. The use of converters, adapters, dongles, etc. will prevent the TV-out feature from working correctly.
    Sincerely,
    Andrew S.
    Intel(R) Technical Support.
    How to make S-video cable yourself
    How to make S-video cable yourself part II
    Slovenia, Europe
    best on-line radio
  2. #352
    sdh
    sdh is offline
    Jan 2009
    I have tested 4 pin s-video connector and found it working. The ony issue there is that it can not be configured to show something different from what is on VGA output (at least I could not figure out). So the idea of using CVBS or S-Video for secondary monitor may not be feasible with this board.
    I also wrote to them about which pin to use for CVBS and this is what they replied:
    Hello, Thank you for contacting Intel Technical Support. The issue you are experiencing is under investigation. Thus, we will contact you as soon as our research department has further information on this case. Important note: Should you need further assistance from us regarding your inquiry, we would highly appreciate if you could simply reply to this email of ours, instead of sending a brand new email, unless it is a different issue/inquiry. Thus, we will be avoiding duplicate incoming emails, and we will not lose track of the email thread.
  3. #353
    Jun 2007
    Can you tell more about this cable? Was it 4 pin on both ends, or it was 4 pin on one end and S-video on other?
    Slovenia, Europe
    best on-line radio
  4. #354
    sdh
    sdh is offline
    Jan 2009
    Quote Originally Posted by miko55 View Post
    Standard S-Video cable, 4 Pins on both sides, connected to a CRT TV. To connect to my car LCD monitor, I need CVBS out and for that Intel suppport told to wait. Still is is not extended desktop, same video on VGA and S-Video output. So hopes of doing different videos using this board look slim to me.
  5. #355
    Dec 2008
    Angry help please
    Quote Originally Posted by veronicathecow View Post
    Hi Paul, "Don't Panic" First chaeck that you have wired up the correct pins to the motherboard (An easy mistake to make) If that's okay you could try using a small screw driver to short the pins to check your switch (be careful, although there are no dangerous voltages you could short something else out. Also make sure you touch the metal of the case first to discharge any static.
    Finally try reseting the BIOS see the Intel site for that.
    All the best
    Tony
    Can anyone help, I am new and have put together my carpc for a month now.. the problem is I can't get any power to turn on the Mobo, at first i thought that it was a mobo issue so i got a new one sent to me and reconnected it and still no power. I am using the intel atom 330 dual core mobo and the m2-atx dc-dc. i am sure that it is all connected properly, but not sure why it is not turning on. the green light turns on when connected but the cpu fan does not spin .. i also have the p4-p4 cable connected to the mobo as well. i am getting all 12v from the m2..
    any help on toubleshooting or suggestions.
    how do you short out the power switch?
  6. #356
    Jan 2009
    Hi if you check earlier in this thread you will find that someone else had this problem. Use the the "on" pins to start the Mobo up. Enter the BIOS and set it to startup on power on (Can't remember which BIOS setting exactly but go through the thread and you should find it.)
    All the best
    Tony
  7. #357
    Jan 2009
    Shorting out the power switch. Look at the chart that came with the MoBo. There are two pins marked power. If you don't have a suitable connector linked to to a switch you can just short them out with a small metal object like a screw driver (At your own risk. There are no dangerous voltages present but you might short out the wrong pins and damage the board. Also make sure you earth yourself first to reduce risk of static damage.)
    Tony
  8. #358
    Jun 2007
    Shorten the pins marked with red colors. Read manual before doing it.
    REgarding S-video: On board S-video has 7 pin connector. IF you will use 7 pin adapter it won´t work. When using 4 pin bidirectional adapter works pine.
    Slovenia, Europe
    best on-line radio
  9. #359
    Dec 2008
    thanks guys, i've shorted the pins marked in red on the mobo, the fan starts up and spins now, but i didnt hear any beeps indicating that the board has booted up, i have my Lilliput connected as well and it says that there is no video input now i am totally clueless, i tried connecting my desktop monitor and still no video..again this is a new board and i have yet to accomplish anything i was excited about this but now after more than a month i am very frustrated
    anyone know what this new problem might be, i have 1gb mem card connected to board """ NO INPUT SIGNAL"""" AARRRGGGGHHH
  10. #360
    Jan 2007
    Quote Originally Posted by seninha View Post
    I use this ATI card:
    ATI 7000 PCI
    Specially because it has a composite TV-out. I already tested 3 different PCI card with s-video and none of them where able to give image to my headrest screens.
    Whit this card I had right away image.As soon as system is booting ,headrest monitors are receiving a signal.
    i would assume you just used a RCA splitter for the headrest monitors? thats what i am planning on doing....how is the quality? what headrest monitor do you use...i could use a recommendation with all dozen of monitors they have on ebay....
    thx
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 09:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
