Page 37 of 69 FirstFirst ... 272829303132333435363738394041424344454647 ... LastLast
Results 361 to 370 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #361
    Jan 2009
    Hi IT09, I'm not sure how new to PCs you are but you have got a memory stick on the M.B. and not just a "i have 1gb mem card connected to board"? I.E. Flash card?
    You must have RAM in there.
    Cheers
    Tony
  2. #362
    Jan 2007
    Quote Originally Posted by the_gooner View Post
    i was hoping for a lot less than that, m2atx metions that most systems use 50-150mA think i could handle anything up to 250mA as the cars used near enough every day
    anything under an amp should be ok as long as you drive your car every couple of days... i have had my laptop running on standby and i took roughly 0.2 amps the car actually took more than that in standby..0.4 amps....so 0.6 total....
  3. #363
    Dec 2008
    veronicathecow
    Im sorry i ment to say I have 1gb of ram on the board, is this to much for this board, it said it is capable of up to 2gb.
    could this be the reason i am getting the NO INPUT SIGNAL on my monitor
  4. #364
    Jan 2009
    No mine is running 2gb no problem but it is worth checking on the Intel website to ensure that the RAM has been tested with this Mobo. Also try removing power and data cables to both CD and HDD and also remove any pci cards (Ensure main power is switched off first). Check the RAM is properly seated (It can only go one way around and it should "Clunk" into place at each end. Now see if it boots
    Tony
    Beyond that I am stumped.
  5. #365
    Dec 2008
    I just purchased a new 1gb mem stick of ram,(kingston) and switched it out with the previous one i had, still No Video Input
  6. #366
    Jan 2009
    Tricky! The fan starts and the green light comes "on" and you have the 4 way Intel CPU power lead plugged in?
  7. #367
    Jan 2007
  8. #368
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    Quote Originally Posted by sgtpepperaut View Post
    That is it.
  9. #369
    Feb 2008
    TEXAS
    Quote Originally Posted by lt09 View Post
    veronicathecow
    Mine did something similar early on.
    Do you have a hard drive attached? If so is the hard drive not spinning up?
    I got frustrated with it and worked on my monitor install for a few days. When I got back to the MOBO it worked fine. Pull the battery out and leave it for a day.
    If the hard drive is spinning up and it could be switched to to the S Video output. I had this happen at some point but I had been using both the s video and the VGA output.
  10. #370
    Dec 2008
    Has ANYONE else had these problems..... if so any solutions?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 09:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
