Page 40 of 69 FirstFirst ... 303132333435363738394041424344454647484950 ... LastLast
Results 391 to 400 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #391
    Mar 2007
    Rutherford, Australia
    Nice work jo. I'll keep that locked away for use if we ever get this extended-desktop stuff working.
    I'm A bit dissapointted that those two extra pins between 1 and 2 on the 7 pin plug didn't do the trick. In the IEGD driver for the 945GME chipset I appear to be able to select between S-Video, Composite or RGB, so I don't know if that means different hardware is required, or if the pins change personality depending on the driver selection.
    Lukeyson
  2. #392
    Variable Bitrate seninha's Avatar
    Dec 2005
    Holland
    Oh man, what would it be nice if we could extend our desktop to a second monitor.
    Right now I use a PCI ATI card. Works great, only problem is that by using the PCI slot I slow down the wake up from hibernation.
    So if we could extend the monitor using the onboard VGA my system would wake up in less then 25 second,instead of the 54 that it takes now
    Gods right foot!!
    Renault Grand Espace 3.5 V6
  3. #393
    Newbie jozasa's Avatar
    Feb 2009
    Unhappy
    Quote Originally Posted by Lukeyson View Post
    Lukeyson
    Thanks! I was disappointed too. Maybe it is a question of a special driver (the IEGD?) options to get composite video to appear in some of the pins, but with the current intel driver, it is simply not possible. It is very annoying that Intel advertises it and then you have to end up soldering your own cable to get it working in a decent way!! I'm surprised too that commercial S-video-to-Composite adapters work so different and give different results.
  4. #394
    Variable Bitrate bemenaker's Avatar
    Nov 2008
    I have been playing around with IEGD 9.0.2 all day making driver builds. I have one that looks like it is outputting 800x480, but it is "letterboxing" it in an 800x600 screen. I have the dec31 bios installed, (supposed to give 800x480 ability).
    Am I missing a monitor setting or is this still anemic driver support?
  5. #395
    Mar 2007
    I'd suggest using Powerstrip to try and make clock and res adjustments to your display on the fly, without having to go through the tiresome change-compile-install process required of IEGD.
    When you get the right mix of frequencies and timings you can then feed those into a custom DTD video mode in IEGD.
    Lukeyson
  6. #396
    Nov 2008
    It seems like the problem is different than just a timing issue. It acts like it still has an 8x6 window but is only drawing 8x480. Both the Lilliput 8" and my Acer 22" lcd report they are receiving an 8x6 signal when I get this setup. It seems like I can pull this open to effectively get what I want, but I'm way overscanning 8x6 to do that then.
  7. #397
    Mar 2007
    No update on 945GC with IEGD yet. Our source has had to escalate direct into Intel - which is what we were after.
    If anyone else has access to an Intel Distributor with a Field Applications Engineer - please help to convince Intel to support us.
    Lukeyson
  8. #398
    Vendor - Mo-Co-So
    Nov 2005
    It is quite easy to get the 800 x 480 resolution with this board if you are running XP. Do the BIOS update (from 12/31 that enables support of 800 x 480), and then run regedit. Find the X and Y resolution settings. Manually change the settings to 800 and 480 from whatever they are set to. Get out of regedit and go to the display properties and you will be able to verify that you are running in 800x 480.
    The only problem I have found with this is if you ever increase the resolution past that point you will not be able to set it back to 800 x 480 in the display settings. You will have to go back into the regedit and do it that way.
  9. #399
    Newbie miko55's Avatar
    Jun 2007
    Ljubljana, Slovenia, Europe
    Could you be more specific about location of xX and Y setting.
    please
    edit: I found it and makeit work in first try.
    warning: the described procedure at our own risk
    For others: Start-> Run. Type in regedit. Select hkey_current_config -> system -> CurrentControlSet-> Control -> Video.
    Explore folder, extend every menu option to its limit. There is only one folder containig your current setting. Pay attention to entry DefaultSettings.XResolution and DefaultSetting.YResolution. Both entrys must have the same number as your current desktop resolution. Click on entry you want to change. Convert from HEx format to decimal. Change value from 600 to 480. Click OK. Close the window. Change resolution.
    sorry for type and other error.
    Slovenia, Europe
    best on-line radio
  10. #400
    Nov 2008
    I was looking at this last night and I believe he is talking about:
    HKey_Local_Machine/system/currentcontrolset/hardware profiles/current/system/currentcontrolset/control/video/{enumeration of your video}/monXXX
    This is where I found what looks be what he is referring too. My stuff is in my car half installed, so I won't be able to check it out until later today.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 09:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
