I increased video resolution, changed regestry and there the new resolution showed up. It works for me.
@ bemenaker: true
I think Miko55 is right on with his directions, however I need to check them to be sure. I have all of the information at my office. I will put it up tomorrow. One thing I know he is right about it that YOU ARE MAKING THESE CHANGES AT YOUR OWN RISK. Don't blame me if you screw your registry up!
It is pretty simple over all and a lot easier then trying to convince Intel to release or support a custom BIOS on an entry level board.
@ bemenaker: true
Slovenia, Europe
best on-line radio
Data sheet for Chrontel CH7021 / CH7022, detailed information at the bottom.
Slovenia, Europe
best on-line radio
Miko, what screen are you running? I did the registry hack last night, and I got my board into an 800x480 setting but again, I'm not getting it to display on the entire screen. I'm running an 8" lilliput. The screen didn't make it all the way to the top of the LCD, but it was displaying the full picture.
Just got this board to replace my sp1300 and everything is running great except the audio. Anyone have trouble getting the audio drivers to work?
@ bemenaker: If you have VGA video output it should work. On S-video it is diffrent story, which I am try to hack. Can you please put some photo on?
@ refuse: drivers from intel side should work. The only way I got in trouble with drivers was, when I instaled winamp before audio drivers. Instalation proces: drivers first, audio program second
Slovenia, Europe
best on-line radio
any luck with working home brew graphics driver supporting extended desktop. Please share testable version of drivers.
To what do you want to extend desktop to? Second monitor, Tv...
Slovenia, Europe
best on-line radio
TV or Monitor connected to S-Video conector.
Use 4 pin S-video cable. It works.
Slovenia, Europe
best on-line radio
