Page 46 of 69 FirstFirst ... 363738394041424344454647484950515253545556 ... LastLast
Results 451 to 460 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #451
    Jan 2009
    Yes, I have the latest BIOS (0150), still issues with USB devices
  2. #452
    Jul 2008
    Lockerbie Scotland
    Does anybody else find that this boards quite temperntial ?
    its been in the car for a couple of months now.
    every so often it frezzes and restarts itself. now the hard disc is a 3.5" at the min as i had a spare in the house so fitted that. however the case itself is only half bolted onto the back seats as when i went to put in the rivi nuts i found that there was no real metal behind and so theres only the 2 top bolts holding it in place
    so ive not worked out if its the board, hard disc or the mounting.
    sometimes it works fine done a 90 mile trip never crashed once yet ive done a short 10 mile one and crashed 5 times.
    currently tring to source a new case as the one ive got is more disged for server racks so aloough thin (45mm i think) its rather long. and a laptop drive for it as running out of space on the main computer in the house so could do with getting the HD in it
    Prob 60% complete
  3. #453
    Mar 2006
    Blog Entries
    1
    Replaced the 40x40x10mm northbridge fan with a SilenX 14dBA 5 CFM and I'm happy to report, it's very quiet! I thought I'd share this info in case others are interested.
    http://www.newegg.com/Product/Produc...82E16835191001
  4. #454
    Aug 2006
    Disable onboard graphic
    Hi, any one know if there is a way to disable (not only in the device manager) the onboard gfx? I use a PCI gfx (ATI FireMV 2200) and I don't need the onboard gfx. The gfx heat sink gets pretty hot even when I don't use it. I can't find a setting in the BIOS for disabling the onboard gfx.
  5. #455
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by DrLove View Post
    the only way to disable the chip itself would have to be through the BIOS.. if there is no option, then you prob can't do it
  6. #456
    Mar 2009
    near Rochester, NY
    There should be an option for which graphics device to use first in the BIOS. That chip is more than graphics though, it handles memory access and basically all traffic to the CPU from everywhere else passes through it. As it is designed on an old process, it will likely always be rather warm. What we need is a board using Atom and a matching low-power chipset.
  7. #457
    Apr 2009
    Question Composite video found?
    Quote Originally Posted by dschu View Post
    The composite signal can be found on the on the second pin from the right (bottom row).
    I could not find any composite video output in ANY pin of the S-video connector in this motherboard, either. Just the separated luma and chroma signals, and once enabled TV out in the Intel driver config.
    Can you reconfirm you did find composite video in the second pin from the right (bottom row), as you say? Because maybe my MB is defective, then! Or am I missing addtitional configurations?
    Thanks!
  8. #458
    Mar 2009
    Quote Originally Posted by jotavalla View Post
    Thanks!
    Hi,
    Initially I couldn't find the composite signal either, but that was because I used the S-Video signals a few moments earlier - i.e. before you boot XP, you must decide whether you want to use composite or S-Video. You can't switch between them (whilst XP is running) or use both at the same time.
    So this is the pinout for the composite signal I used (view of the back panel):
    Code:
    * = Ground
    * = Composite signal
  9. #459
    Apr 2009
    Hi,
    Code:
    * = Ground
    Thanks a lot! Tested as you said, and working!
    I did not realize that it's either S-Video or Composite, but not both at the same time. And the decision has to be taken before you boot Windows!
    It is unfortunate this is not mentioned in the documentation of the board by Intel. What a headache this issue has been for me!
    Again, THANKS A MILLION!!!
  10. #460
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by strikeback03 View Post
    What the heck are you talking about? I thought we ARE talking about an atom board here? That's what this whole thread is all about...
    Tidder
    Try RevFE
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 08:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 02:56 PM
