Page 49 of 69 FirstFirst ... 394041424344454647484950515253545556575859 ... LastLast
Results 481 to 490 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #481
    Nov 2008
    Ahmedabad, India
    Quote Originally Posted by muntos View Post
    Hello guys, do you have problems with USB devices and this mobo ?
    This is driving me crazy, I have one USB Modem model (Huawei E180 ) that once is plugged in the mobo freeze at POST code 94 ("Clearring keyboard buffer"), it don't go any further with this USB modem.
    Also with X-FI 5.1 USB soundcard I have over 15 seconds delay at boot (right before POST screen).
    I am facing the same problem with my GCLF(SINGLE CORE). Even i updated my BIOS to the latest. But still same issue with my X-Fi USB. If i remove the USB cable from CARD. System POST quicker otherwise have to wait for 30 seconds.
    In latest BIOS Released. [LF94510J.86A]
    • Fixed an issue where the system would hang during post under
    certain conditions.
    But still it didn't solve my issue.
    I dont know weather its a BIOS problem or Sound Card overdrawing the Current from USB ?
    I am thinking to get this Dual Core Atom Gigabyte Board.
    http://www.gigabyte.com.tw/Products/...ProductID=3082
  2. #482
    Mar 2007
    Rutherford, Australia
    I remember having a boot problem with a USB device attached. I can't remember exactly what I did. I have vague memories of either fiddling with in the bios for disabling booting from USB devices, but I also remember playing with legacy interfaces (com/lpt etc) at the same time.
    Lukeyson
  3. #483
    Apr 2009
    Quote Originally Posted by jozasa View Post
    I tested all pins in the 7-pin connector and I did not find any composite video output, as advertised by Intel (????!!!!).
    The solution is to use a standard 4-pin S-video to RCA cable. I tried some comercial ones and either I got a black-and-white picture or a very blurred colour.
    Finally I got the best results by making my own cable as shown in the image
    Confirm the positive result.
    But when I'm on XP the screen appear not 100%. A lot of desktop's part is outside of the screen! I try to chane resolution with no success. When I boot the margins is ok (the booting sequence is perfect) why on XP not?
  4. #484
    Constant Bitrate b3tts32's Avatar
    May 2006
    Arlington, Tx
    Quote Originally Posted by nisarg86 View Post
    certain conditions.
    Have you disabled legacy usb devices? That'd probably be something you want to try.
  5. #485
    Aug 2007
    Where is our ACPI switch and what does it mean to flip it? computer isnt working and thats what I was told to do?
  6. #486
    May 2006
    Calgary, Alberta
    So what's the final verdict on this board? I'm thinking of upgrading to it from my Via Epia M10000.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  7. #487
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    im not overly impressed with the sound...
    its not bad, but i find it a bit lacking
    otherwise its been sweet
  8. #488
    Mar 2006
    Blog Entries
    1
    My internal sound card works good enough, haven't bothered re-using my external USB soundblaster 24bit from a previous carpc build.
  9. #489
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Quote Originally Posted by Maheriano View Post
    Ditto.
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  10. #490
    Oct 2007
    Assens, Denmark
    I upgraded from the M10000, and beside the RTHDCPL.EXE audio problem that really isn't just related to this motherboard, I haven't had any other problems. I have only used one IDE drive and nothing else. Updated BIOS via FAT32 formated USB key. Booted and installed XP from NTFS formated USB key. running XP from IDE HDD with no problems beside the RTHDCPL.EXE audio thing. I really like the board...
    Henrik
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 09:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
