Page 52 of 69 FirstFirst ... 2424344454647484950515253545556575859606162 ... LastLast
Results 511 to 520 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #511
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    As my luck will have it, my board just malfunctioned just before the 500mi trip i need to on later this week. Installed it in the truck last weekend and was working fine. Today all of a sudden the screen went black. Now, i DON't even get POST from the BIOS
    When the M-2 sends the "on" signal, the fan starts to spin and i get the green light on the MB; the HDD makes a sound for a microsecond. All along NO POST.
    I tried another HDD but no change; remove the battery and reinstalled still nothing. The P4 connector is installed and show power with a test light.
    Next i'm going to hook it up to a conventional power supply and see what happens.
    If anybody have experienced this or have any suggestions - please chime-in.
    I need to get me a map - just in case.
  2. #512
    May 2009
    Is anyone running this board with a laptop IDE drive?
    I'm planning a setup and i have pretty new WD laptop IDE drive laying around, figured I could save some $$ on the HD if i can use it.
    Thanks!
  3. #513
    Feb 2007
    [QUOTE=joshuo;1319914]Is anyone running this board with a laptop IDE drive?
    I run mine with an 80 gig laptop ide drive, off road even, no problems here.
  4. #514
    Mar 2008
    Australia
    I run mine with an IDE laptop drive in my 4x4 and the car gets driven hard in the bush and the carpc hasn't missed a beat
  5. #515
    Mar 2009
    Brazil
    Quote Originally Posted by treetop777 View Post
    I had the same problem, last week, I returned the MB to the supplier, still waiting...
    Mauricio
  6. #516
    May 2009
    Quote Originally Posted by millsy View Post
    So I suppose you guys are using one of these?
    Rosewill Laptop to Desktop hard drive adapter
  7. #517
    Feb 2007
    Yep, mine is computer market $5.00 special, i have also eliminated nearly half of the atx wires,much easier to route the cable.
  8. #518
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by mobenaus View Post
    Mauricio
    Yeah, took it to a computer shop and they couldn't figure it out, fortunatly, they had a new one in stock so i bought it.
    Looks like i'm going to have GPS afterall
  9. #519
    Sep 2005
    Pomona, CA
    I just got this mobo last week (upgrading from VIA M10000) and already have a M2-ATX PSU setup and ready to go. I finally got everything connected - I had to use a molex to 2x2 12v cable to get that connected (do 2x2 to 2x2 cables even exist?) - so thought I was ready to go today. I turned on the ignition and all I got was the green light on the mobo and a dim HDD light. I don't have the power led hooked up anymore because my case connector is 3 pins wide, but the mobo takes a 2 pin connector, plus I don't need a power indicator when I get this thing running. I tried reconnecting the memory twice and disconnecting everything but the mobo from power. I also tried shorting the power pins on the mobo and setting the M2-ATX as always on. All I got was the green light. The only thought I have left is that my battery doesn't have enough juice, but it turns over just fine and all interior lights and radio are fine. I guess the next step is to somehow hook it up to a regular PSU, but don't have one of those around at the moment, so maybe tomorrow.
    Any other ideas?
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  10. #520
    May 2009
    If the car is running, that PSU should have plenty of power for the MB. what is it rated at? 35W? and the M2 Atx goes up to 160. I would suspect the memory at this point.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 08:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 02:56 PM
