Page 62 of 69 FirstFirst ... 12525354555657585960616263646566676869 LastLast
Results 611 to 620 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #611
    Dec 2008
    Quote Originally Posted by kapone View Post
    huh?? I plugged the adapter in, plugged a standard RCA cable out to my monitor and I get video? Even the bios. Didn't have to configure a single thing other than bumping the resolution down to 640x480 from the default 800x600 (the BMW monitor is really low res) and that too is certainly optional.
    I repeat, I didn't configure a single damned thing. Plug and play. I am however using Windows 7 as I have said before and with the latest Intel drivers.
    thats surprising honestly, you must have a more current motherboard/video chipset- or maybe one that is designed to output a dummy signal on the composite line. i have never been able to get video off composite unless im using a real svid cable though, so apparently i just havent come across boards that can.
  2. #612
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    Have you tried updating the BIOS to the latest version?
    yes to the Bios
    Maybe it's not in the bios but the OS and latest drivers.
    Where did you obtain the latest drivers? Intel?
    I think i actually went to the website and it reported back to me that i had the latest drivers.
    I now have a strong feeling it's because you have Win7 - which tells me i can play around with the software to get this modification accomplished (as trader said earlier - i can force it).
    Back to the registry....
    On another note Kapone - i was a little bummed out to find that my spare power supply is a M1-ATX not M2... i was hoping to use the 12v railing for my monitor but no sweat.
    I also was checking the volts with my Fluke Multimeter (sweet). I noticed that my USB dvd rom would not start up with any of the red wires (4.9v to be exact). My Fluke is not capable of reading amps (bummer) so i'm wondering if the DVDROM is more demanding than the USB Hubs?
    I then checked other wires on the harness and one in particular came out to 5v exactly - the purple wire. I connected my DVDROM to it and - voila!! it works.
    I will keep you posted on my results (and my svideo situation).
    THanks again
    AD
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  3. #613
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Yes, there is "some" blurriness using the adapter on text. Moving video is fine. However, I suspect that will be the case with almost all composite video inputs. Composite video is interlaced and at that low resolutions some blurriness is almost a given.
    I finally went ahead and purchased this adpater. It does show in color, videos are fine but the text is a little blurry. I am glad I got it.
    Gee
  4. #614
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Is it possible to disable PCI express in the BIOS as I'm getting a pci.sys error using my pre-SP1 XP Pro install CD?
    Vauxhall Astra SXi Car PC installed.
  5. #615
    Aug 2006
    New Ro, NY
    Quote Originally Posted by navputer View Post
    @Navputer
    What operating system are you working out of?
    I don't mind blurry text as the second monitor is for rear passengers (kids) to watch video.
    Here's the odd thing. I plug the adapter in, and windows XP does not see it. I plug in an 8-pin s-video cable i have with 2 rca video out and windows responds with a chime and TV-out then becomes available. I've come to the conclusion it's windows XP. Unless of course someone has gotten the adapter working under XP - then i need to with plan b.
    P.S. Trader007 may have a point. The chipset and release of different models may be floating about. Who knows?
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
  6. #616
    Jan 2007
    DFW Area
    Quote Originally Posted by afterdigital View Post
    @Navputer
    I am running Window XP SP2 but with the original mb (cd in the box) drivers. I did not update the drivers like others cause everything worked fine.
    I plugged in the adapter then turned on the PC, intel control panel showed a dual monitor connection (primary/secondary). When I unplug it, it went back to single monitor. I can check my mb version but definitely I am running Windows XP.
    Gee
  7. #617
    Aug 2006
    New Ro, NY
    What service pack?
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    Finished Project
    Car Hacking
    WorkBlog
    Video
  8. #618
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Just upgraded to this motherboard, and operation is much faster than my old M10000. The only issue I see is sometimes when booting, if you hit the F2 key to soon to try to enter the BIOS setup, it gets stuck there until you remove power from the board. No matter how many reboots you do, it will still be stuck there until you remove power from the motherboard..
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  9. #619
    Jan 2007
    DFW Area
    What service pack?
    I am running Window Service Pack 2. Also attached is my PC information (shows video driver).
    Attached Files Attached Files
    Gee
  10. #620
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Here's how my equipment "looks" in the trunk. I'm still cleaning up some of the wiring and a couple of other audio related things that I need to finish.
    Regarding the wireless router...what kind of adapter are you using it for?
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 09:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
