Page 63 of 69 FirstFirst ... 135354555657585960616263646566676869 LastLast
Results 621 to 630 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #621
    Jan 2009
    Quote Originally Posted by hexxamillion View Post
    Regarding the wireless router...what kind of adapter are you using it for?
    The router IS the adapter. The PC's onboard gigabit is hard wired to the router using one of the router's ports. The router's "radio" works backwards. It is not used to connect TO the router, but is used to connect the router TO an access point, which is my home network (or could be any open AP). That's what the DD-WRT firmware allows, among other things.
  2. #622
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Ok. Gotcha. Nice setup.
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  3. #623
    Constant Bitrate vull's Avatar
    Oct 2007
  4. #624
    Low Bitrate Dexamenus's Avatar
    Nov 2008
    Quote Originally Posted by vull View Post
    Yes it sure does
  5. #625
    Dec 2007
    AZ
    Check that your power supply does not already come with this cable. But yes you will need this.
    Recent Proj
    Old Proj II
    Old Proj I
  6. #626
    Oct 2007
    ok thanks
    i was thinking of getting a pico-psu90, but that might not work very well with this board?
    m2-atx seems ok i guess, but it needs the extra cable
  7. #627
    Nov 2008
    m2-Atx comes with this cable already!
  8. #628
    Oct 2007
    Quote Originally Posted by Dexamenus View Post
    this seller takes it out from the box and sells it separately then?
    http://linitx.com/viewproduct.php?prodid=10917
  9. #629
    Sep 2009
    Hey guys,
    This question is not really following the question, but it fits under this thread... I was wondering if anyone knew what the power consumption of the D945GCLF2 is when its in S3 standby mode? Also, if anyone is running it in S3 standby mode with the M2-ATX PSU?
    Thanks..
  10. #630
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Chris (LinITX) would not do that. His reputation is second to none in the UK.
    You can have confidence that he is highly recommended at digital-car.co.uk, there is no reason to be suspicious (although I do understand why you might be concerned).
    Dave
    Vauxhall Astra SXi Car PC installed.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 08:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 02:56 PM
